Chris NottBadger5
    Aug 2013
    Cold engine noise very annoying!
    Hopefully somebody on here might have had this fault before with a BAM engine S3 so thought i'd put the post out there...
    Ok, the car is a 2005 Cupra R, (Ok ok its not an S3 but still a BAM engine!) 34,000 miles.
    When I pull away when the car is cold I get a 'clack clack clack' metallic (ish) noise from the engine.
    -It seems to be from the drivers side of the engine bay / drive belt side
    -The 'clacking' is relative to engine speed, most noticeable up to about 3000rpm
    -It only happens from a cold start, and even then i'd say it only occurs 75% of the time
    -It stops after 5/10 mins of driving
    -It doesn't make the noise at idle or when revved, only when moving / under load
    -It's not the auxilary drive belt tensioner (has already been replaced)
    -It's not the alternator clutch pulley (also replaced)
    -Oil level is always on MAX
    -Its been getting progressively worse over the last 18 months
    If anyone has had this before please let me know, it's doing my head in!
    Thanks in advance to anyone that can help.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    VVT unit maybe? got any vids of the noise?
    <tuffty/>
    Aug 2013
    No vids at the moment. Its only under load and now there every time from a cold start, also i can get it reversing on the drive
  1. Very annoying rattling/knocking noise?
    By Jonezy87 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th July 2010, 22:14
  2. engine noise on start up
    By S3JUS in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd November 2004, 18:43
  3. TDI engine noise
    By vwed1 in forum Volkswagen and other VAG
    Last Post: 23rd October 2004, 00:12
  4. Engine Noise in 4th and 5th
    By BiffS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th October 2003, 08:41
  5. Cold Startup Noise
    By mramage in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd January 2003, 21:52
