Volks AutosAH Fabrications
    intermittent loss of boost after approx 2500 to 3000 rpm on 8l s3
    Guys
    Please don't flame me if this has been asked 1000 times before, I have had a look at the faqs before posting.
    My s3 is a 2001 model with 90K miles. One owners before me and full audi or audi specialist service history.
    The cars idles and runs v smoothly but there is as discernible loss of power at 2500 to 3000 rpm. I can't confirm that this happens 100 percent of the time or that the point of degradation is consistent, may vary depending on which gear I am in.
    Not sure if it's relevant background, but when I bought the car approx 3.5 years ago, there was a lot of variation in the turbo boost. Sometimes the car would rocket along and at others was quite pedestrian. It has now settled down with the boost being quite modest - up to the point where it cuts out.
    I have read on other posts that the cause could be a cracked or split hose. Which ones should I check and where are they located - is there a good reference sheet that identifies which hose is which?
    Any help or suggestions much appreciated.
    Tim
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,598
    Sounds like an overboost or similar causing limp mode and the ECU to pull back to protect the engine...
    First thing to do is scan for fault codes... then check for spilt pipes etc particularly going too and from the N75...
    You could also try unplugging the N75 electrically to see if the car drives ok (albeit on much less boost)...
    Would be an idea to list any mods you know you have and if the car is mapped...
    Beyond that you will need to log the ECU with VCDS to see whats going on..
    <tuffty/>
    Tuffty, thanks for the reply. The car has no modifications and has been owned and driven by two responsible 'over 40s'!
  1. A4 1.9TDI - intermittent loss of power
    By chuffy in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th January 2008, 00:09
  2. Tempory loss of boost? Help!!!
    By Andy...S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th December 2007, 10:22
  3. Loss of power after super-unleaded shortage :(
    By joshxs in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th October 2007, 13:30
  4. Audi 80 1.9 TDi - intermittent loss of power
    By horlix in forum Diesel forum
    Last Post: 2nd May 2006, 22:07
  5. Sudden loss of boost
    By AudiA4rulz in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th December 2004, 18:26
