AH FabricationsSky Insurance
    Platty's Avatar
    Aug 2013
    7
    A3(8L) 1.9TDI Quattro rear subframe sawp
    After having a look under the car a couple of weeks ago I noticed the rear subframe is rusty. Most probably an MOT failure so I'm looking into swapping the whole thing out.
    Having seen a few S3 subframes going on eBay, does anyone know if they are compatible? I assume the control arms are longer to allow the S3's wider track? What about hubs and trailing arms?
    I'm hoping to build a completely reconditioned subframe assembly on a bench at work, then just swap out old for new one weekend.
    Current stable
    02 A3 1.9TDI Quattro sport - Daily hack
    08 MINI Cooper S - Showcar
    00 VW Polo 1.4 16v - Girlfriends thrash
    Platty's Avatar
    Aug 2013
    7
    Anyone able to offer advice?
    Current stable
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    Fairly sure they are the same bit of kit... even though the S3 has wider arches the rears sit in quite a bit suggesting the rear track is no different (uses the same suspension components so no reason to believe this is different)
    I don't think S3 arms are a differnt length... have fitted KW tie bars to an A3 TQS before and they are not a different PN
    <tuffty/>
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,892
    All the rear subframes I've seen have rust on them, it's not an mot failure is it? Unless its about to drop off, I wouldn't disturb it personally.
    You've got to have a laugh!
    Platty's Avatar
    Aug 2013
    7
    Thanks Tuffty, I'll go with an S3 item in that case.
    Jojo, there's more rust than subframe!
    I'll be fitting new brakes/discs and swapping out bushes anyway. It'll be easier to do it all on a bench then just swap the lot over.
    Current stable
  1. 1.8T or 1.9TDI quattro sport
    By dgannon69 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th January 2006, 19:48
  2. Would this be a good buy? A3 1.9TDI Quattro Sport.......
    By boxerman in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th November 2005, 09:44
  3. A4 Quattro Rear Diff Seals
    By kipps in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th November 2005, 18:50
  4. A3 Quattro Rear Diff/Haldex Coupling Oil Change
    By imported_rob911 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2004, 10:50
  5. A friend's A3 1.9Tdi Quattro
    By benk in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd September 2003, 15:46
