Badger5AH Fabrications
Results 1 to 7 of 7
Like Tree2Likes
  • 1 Post By Westy
  • 1 Post By Westy
Thread: Full brake fluid change
    Dec 2011
    630
    I'm having to replace my front discs I thought I would replace the fluid as well so I bought some rbf600 as read on here it pretty good,any one any tips on changing the fluid as I've read about people flipping the seals on the master cylinder
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,280
    Quote Originally Posted by Goubo1 View Post
    Buy an Ezibleed kit and an 11mm spanner and it's a fairly simple job.
    Goubo1 likes this.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Dec 2011
    630
    Quote Originally Posted by Westy View Post
    ill go halfords tomorrow and buy one I see they are only £20
    Westy's Avatar
    Dec 2008
    17,280
    Yeah cheap and the easiest way to bleed brakes. You connect up the Ezibleed to pressurise the system then you go roun each calliper and crack the bleed nipple with an 11mm ring spanner to bleed them.
    S3 Build Thread
    Dec 2011
    630
    i have 996 4 pot calipers on the front are they 11mm too do you know mate ?
    Westy's Avatar
    Dec 2008
    17,280
    If they are brembo then yes they should be.
    Goubo1 likes this.
    S3 Build Thread
    Dec 2011
    630
    cheers mate
  1. Brake Fluid Change & New Tyres
    By adamrawling in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th March 2006, 10:49
  2. Brake Fluid Change
    By yoda in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th February 2006, 15:19
  3. Bi annual service & brake fluid change costs?
    By MrLapou in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th January 2006, 10:44
  4. Brake fluid change
    By ImS3ola in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th June 2005, 14:58
  5. Brake Fluid Change
    By Masterm8fo in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th December 2004, 23:41
