I'm having to replace my front discs I thought I would replace the fluid as well so I bought some rbf600 as read on here it pretty good,any one any tips on changing the fluid as I've read about people flipping the seals on the master cylinder
Yeah cheap and the easiest way to bleed brakes. You connect up the Ezibleed to pressurise the system then you go roun each calliper and crack the bleed nipple with an 11mm ring spanner to bleed them.
