Sky InsuranceJMB Retrofits
Results 1 to 9 of 9
    Bigandbald's Avatar
    May 2013
    Basingstoke
    105
    Audi S3 clutch??
    Morning all,
    once I leave my car for a few hours or more, usually overnight I come and drive it and the clutch pedal has sunk down half way. Now if I don't move it the biting point will be right at the bottom, so I pull it back up and it is back to normal!
    any ideas guys???
    `02 S3 AMK now sold, need more doors so along comes an '04 Seat LCR Bam 225, badger5 tip, s2000 filter, very high mileage now with badger5 remap @ 275.5bhp.
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    899
    Add Vex182 on Facebook
    Sounds like the clutch wants bleeding, maybe a failing slave cylinder?
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Bigandbald's Avatar
    May 2013
    Basingstoke
    105
    Nice!! Is it easy to do??
    Dec 2012
    Ireland
    36
    Gearbox out unfortunately : (
    Bigandbald's Avatar
    May 2013
    Basingstoke
    105
    Oh well new gearbox it is then as mine crunches when changing up into third quickly or down to second.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,236
    Whys it a gearbox out to bleed it? You can bleed it off the master cylinder cant you?
    Jul 2013
    31
    dualmass fried i think.
    Had the same, down to the bottom, pulled it up, made it just to home, and it was on the bottom again.
    there was a lot of play on the flywheel what caused the slave cilinder to burn.
    Dec 2012
    Ireland
    36
    it's gearbox out to replace slave cylinder sorry; ) not to bleed it
    Bigandbald's Avatar
    May 2013
    Basingstoke
    105
    Ok thanks chaps, I think I'll have a go at bleeding it. It only sinks down about 1-2inchs.
    fingers crossed all works out ok?
  1. Audi S3 Clutch Size?
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th January 2010, 20:01
  2. Audi S3 clutch problem
    By sakkie69 in forum Parts Requests
    Last Post: 19th March 2009, 10:29
  3. Audi A3 Clutch Noise
    By Jlovett in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th September 2008, 15:28
  4. Audi S3 Clutch / REV problem - HELP!
    By jamiebrayley@yahoo.co.uk in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st December 2007, 00:51
  5. audi a3 clutch pedal
    By josh123 in forum General Technical / How To
    Last Post: 28th April 2006, 14:52
