EM TuningChris Nott
    Jan 2013
    Somerset
    Prop Shaft Flex Joint Replacement
    Hi All,
    So.. I left work a couple days ago, as i pulled away there was a horrific amount of banging underneath! i managed to get the car back to the car park (alot of struggling with the wheels locking and such). Anyway after looking underneath it today (been very busy!) i found that the prop shaft has came completely away from the flex joint and the flex joint is destroyed! Can anyone point me in the right direction as to what i can do about this, or if anyone knows what i will need to repair. It looks an absolute pain in the rear to get too. i have access to a pit and was hoping to do it myself with help from some of my more mechanically minded friends! Any help or advice is much appreciated. Thank you.
    Jamie.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Not that hard to get to, and for your info it is a 12 point m10 socket you will need, never heard this before on these, BMWs suffer from it quite bad
    Jan 2013
    Somerset
    Thanks for your reply, from underneath i struggled to get my fingers close to it, can i remove anything to have better access? also, any idea where i can get a flex joint from?
    Thanks.
    Feb 2011
    Portugal
    161
    Quote Originally Posted by Jamo2013 View Post
    Thanks.
    you have to remove the sub frame, and unbolt half shaft. You need the rubber piece, and one inner piece, that I don't know the name, it's the shaft guide
    Talking about the 800hp by 0-400 S3 : "Is it true that everytime you take this car down the strip, the earths rotation slows by 0.1 % ??"
  1. S3 Prop Shaft
    By Welly in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th April 2010, 17:38
  2. Puzzled - Possible Prop Shaft Query
    By brettp in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th March 2010, 20:41
  3. Help!! Anyone know where I could get a Prop Shaft?
    Last Post: 2nd March 2010, 14:44
  4. Downpipe, worth getting new flex joint welded in?
    By imported_Yaseen in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th January 2005, 09:21
  5. Wanted...Avant 2.5 Quattro Subframe and Prop shaft
    By ims1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th November 2004, 00:50
