Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By LynxE
Thread: Can someone explain some codes to me please?
    Jun 2013
    Sheffield
    73
    hey
    When I bought my 2002 S3 at the beginning of July it had an engine management light on. Car drove fine and the owner said that the code comes on cos the the car is remapped so it's an over boost. He got it reset and then it came on for a couple of days later. Lately it's been worrying me a little so I thought I'd post the codes here. Can anyone confirm there isn't much to worry about or if there is something I I could do to get rid of them permanently?
    17544 Fuel Trim Bank 1(Add) System too lean P1136
    17963 Charge Pressure Maximum Limit Exceeded P1555 intermittent
    I'm guessing the last one is due to over boost?
    Thanks in advance
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    825
    Add Vex182 on Facebook
    17963/P1555 - Boost Pressure Control: Upper Limit Exceeded
    Possible Symptoms
    Reduced power output
    Limp mode
    Possible Causes
    Boost Pressure too High
    Hoses/Pipes incorrect connected, disconnected, blocked or leaking
    Charger Pressure Control defective
    VNT (variable nozzle turbo): nozzles stuck
    Solenoid Valve for Boost Pressure Control (N75) defective
    Possible Solutions
    Check Hoses/Pipes to/between Components
    Check Solenoid Valve for Boost Pressure Control (N75)
    Check / Clean / Replace Charge Pressure Control
    Check / Clean mechanism for variable nozzles
    17544/P1136/004406 - Fuel Trim: Bank 1 (Add): System too Lean
    Possible Solutions
    Check Mass Air Flow (MAF) Sensor
    Check Fuel Pressure Regulator
    Check Fuel Pump
    Check Intake/Exhaust System for Leaks
    Check Secondary Air Injection for Leaks
    Check Vacuum Lines for Leaks
    Special Notes
    Fuel Trim Info
    When this fault is stored and external vacuum leaks are not found, less obvious problems may be present:
    Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80)
    Check Brake Booster and Hoses
    Check Electric Vacuum Pump ( If Applicable )
    Check Crankcase Ventilation System for faulty components. When the PCV or Crankcase Ventilation System is faulty, vacuum is typically present under the oil cap and misfire faults are common.
    To me it sounds like a very poor map on the car, I would get it checked on a rolling road with someone ASAP.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, N249 bypass, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Jun 2013
    Sheffield
    73
    It sounds that bad? Apparently it's been running with these codes for ages. It has an APR remap?
    Will the rolling road do?
    Sorry I'm not too good on this stuff
    Vex182's Avatar
    Apr 2012
    Hinckley
    825
    After a good remap, nothing should come up so something is upsetting it. Best bet is to follow the steps above to see if any of then solve the issues, or it's the map itself. On the rolling road, the sensors can can be monitored, so fuel for example can be monitored in the whole rev range, plus the power output of the car.
    Jun 2013
    Sheffield
    73
    cool, so get it on a rolling road with some diags running. It's in for it's brakes soon so I'll ask them if they do it there. Otherwise there's a couple of Audi specialists near me. Do you know how much this usually costs? Thanks for the replies btw
    Vex182 likes this.
    Vex182's Avatar
    Apr 2012
    Hinckley
    825
    I would expect to pay around £100 for dyno and diagnostic session, depends on the company of course.
    Lewis583's Avatar
    Mar 2010
    834
    Check all your vac pipes first. You may have a split in a pipe going to the DV or possibly actuator, would explain both codes. Lean code due to sucking unmetered air and the over boost due to lack of adequate control of wastegate actuator/DV.
    Worth having a look yourself first, I know I would before paying someone who will do the same.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
  1. Cruise Control - Please can someone check the coding I've found is correct
    By danb986 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd September 2011, 08:58
  2. Can someone explain this (PIC)?
    By The Engineer in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th May 2011, 16:41
  3. VCDS - can someone explain "readiness"
    By mikes3 in forum VCDS (formerly VAG-COM) forum
    Last Post: 13th January 2011, 23:52
  4. n75j ? can someone explain?
    By jazzyc in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th June 2007, 23:16
  5. can someone explain this one??
    By ollyste in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th September 2006, 19:45
