Monster MotorsportChris Nott
Results 1 to 18 of 18
Like Tree2Likes
  • 1 Post By voorhees
  • 1 Post By Greig300
Thread: Audi S3 door blade trim coming off!
    Jan 2011
    Glasgow
    226
    Recently I've realised the outside trim was coming off and was getting worse by the day... I had noticed long before the trim falling off the corrosion bubbles forming on the paint above the trim and was also getting worse. (I went to dealer about the corrosion warranty complete waste of time) anyway, using the screws to take the trim off done nothing. The screws either just turned and turned or were so corroded it wasn't recognisable as a screw. I have now taken then trim off by pulling it slowly off. I now need to know the screw part NO and if the plastic strip that's still on the door can be saved or do I need the whole lot replaced? Any help would be great.
    Here is some images:
    Uploaded with ImageShack.us
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,611
    Maybe this should be a warning to other members,the rusty screws have caused the corrosion of the doors or at the very least helped it along.
    S3 door blade removal guide with pictures.
    Attempting door blade removal later today
    Jan 2011
    Glasgow
    226
    Quote Originally Posted by voorhees View Post
    I agree, it can wreck what is a nice car. It happens fast and is costly to fix (paint) not sure about the rest of the parts. If I were to get another 8L S3 one of the first things I'd do is remove all screws and clean it and fit new screws.
    voorhees likes this.
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,611
    Yeah I feel for you bud but hindsight is brilliant
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,059
    Yeah replace with stainless bolts asap then no more probs.. i think they were m4 x 20mm size
    Jan 2011
    Glasgow
    226
    The plastic strip is still on the door. Does that slide back into the trim?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,839
    Quote Originally Posted by Greig300 View Post
    It should still slide back in. The white nylon strip is pressed in the plastic door trim with a rubber part in between. Over time, the rubber part shrinks, so the nylon part pops off. You can do 'The Doctors' fix, and screw the nylon part back onto the plastic trim and reattach to the car door. Or use longer screws and screw through the door and into the plastic trim, which is what I have done. Buying new ones is silly, they are like £150 each now!
    You've got to have a laugh!
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    If you can remove the nylon insert without damaging it then unibond/glue the inserts back into the trim and then slide back on. The nylon insert should slide off. The screws that corroded hold the blade in place you might need to replace these with self tapers
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    453
    Also if you buy a new one from the dealer it is unpainted!! So you need to get a body shop to match it as the originals are coloured moulded plastic.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,839
    Quote Originally Posted by s3mad_dude View Post
    Still don't understand this? I just purchased my driver side one and bolted on, no paint needed. The shade was very minor difference due to being new, but now weathered, they look the same!?
    New one fitted fresh from Audi!
    Brand spanking new door blade looks like this.
    Knackered one that's been on car for 5years+(I tried to repair it with Araldite, which lasted 6 months, you can see the glue marks)
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,637
    Sounds like it's worth replacing them even if they're not an issue right?
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,108
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Quote Originally Posted by Sam_ View Post
    The screws would definitely be worth changing....but only due to them siezing up and becoming a major headache in the long run if/when you do need to refit the door blade.
    Saying that though- I doubt your screws will rust/corrode that much compared to us UK guys, as we have such lovely weather conditions over here
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    Jan 2011
    Glasgow
    226
    Its definitely the screws that cause the corrosion. It'd replace them all before yours goes the same.
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,175
    Are the screws definitely M4 x 20mm as Dave S3 suggested? I didn't measure them when I replaced the passenger side blade.
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,611
    Quote Originally Posted by The Doctor View Post
    I'm sure they are Paul,so tiny are these things that I needed one from the Stealers and they gave it me free of charge
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,839
    The screws were 27p each from the dealers back in the day, and they come with washers. The replacements I got we're galvanised too I think? Still all rusted over time, as I had to redo the passenger side one.
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    453
    Quote Originally Posted by jojo View Post
    Maybe because yours is pre-facelift?? I dunno but yours look a different colour to mine, a very pale grey. My originals were a very dark grey so I had the new one painted to match. I assumed that was the norm, but Perhaps not!!
    Mar 2012
    131
    My driver side door blade finally gave up the ghost yesterday. Fortunatley the plastic bracket and screws were OK. On inspection the metal insert seems to rust inside the rubber moulding causing expansion and distortion of the rubber which releases the plastic bracket and then results in the failure. I was able to remove the old rubber and rusted metal so the plastic bracket is flush with the blade and then re-bond and screw it back into place - which seemed to do the trick, for now anyway ...
    S3 2003 Avus Silver, Sunroof, Chrome Mirrors, Symphony II, Cruise, Heated Seats, Centre Armrest, Ambient Lights, GTRS Turbo, Forge FMIC, Sports Cats, MillTek, Coilovers ...
  1. Audi S3 Door Fin Trim
    By djx11b in forum Parts Requests
    Last Post: 14th December 2011, 14:58
  2. Door blade/trim/moulding for s3
    By kelk11 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th January 2011, 22:04
  3. Little niggle, outside door handle trim coming away (photos)
    By paul_r in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th January 2011, 16:41
  4. door trim come off!!!photos
    By khalil in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th April 2008, 16:08
  5. drivers door exterior trim fallen off
    By ocalld in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd September 2006, 18:22
