Volks AutosJMB Retrofits
Results 1 to 10 of 10
    Aug 2013
    50
    Gearbox swap on my audi s3 8l?!!!
    Hi lads and lasses, just signed up to this anaing forum! Lots of good info here!! Just bought myself a nice audi s3
    but unfortunately the gearbox whines a little. I'm just wondering how hard the gearbox change would be? I'd look at getting the single DMF while I was there and a sach clutch. I'm reasonably good with the spammers but just wondering if this is a specialist thing? I'd appreciate any help I can get please! Thankyou very much!!
    Martin
    Feb 2012
    Rutland
    132
    Many of these gearboxes whine. I wouldn't worry about changing it out until the box start to feel bad ie. notchy gearchanges. I ended up paying to have mine swapped with a second hand low mileage box which feels nice and smooth, but still whines a little.....
    Dan
    2001 AMK S3 in Goodwood Green
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,277
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    How bad is the whine? Is it throughout the rev range and in all the gears?
    When I had my car completely standard for quiet a while I don't recall my gearbox whining tbh. Notchy gear changes into 1st and sometimes 2nd gear yes....but not a distinctive whine from it.
    What mileage is the car on?
    Chris
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    Aug 2013
    50
    Thankyou for the fast replies! The gearbox isn't a loud whiting noise and not constant I don't think, car is on 139,000
    kwistof's Avatar
    Jun 2010
    SE Kent
    2,277
    Useful thread about it here fella-
    Gearbox whine
    Could be some others if you use the search bar in the top right hand corner....
    2000 S3 APY
    Aug 2013
    50
    Thanks for that link! Ill be sure to read though it and use the search bar to give me some other ideas! You guys have been a great help thankyou!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,568
    S3 quattro box changes are not the easiest thing to do without a ramp but can and have been done on stands on drives as long as you have the time...
    02M boxes are heavy and you will need to drop the subframe to get the box past... you are also advised to remove the transfer box at the back too as this gets caught behind the block when trying to remove making it difficult to get the box off... this is held onto the gearbox by 4 obvious bolts but there is also one in the centre of the drive flange that requires a special tool or very long 6mm allen key to undo else the transfer box won't come off...
    <tuffty/>
    Feb 2012
    Rutland
    132
    Quote Originally Posted by kwistof View Post
    Chris
    Mine only does it on over-run ie. when I take my foot off the loud pedal. Really only in 2nd and 3rd as well.
    kwistof's Avatar
    Jun 2010
    SE Kent
    2,277
    Quote Originally Posted by dancuz View Post
    Personally I'd carry on driving it - maybe drop the oil and replace it to see if it makes any difference.
    Then drive it in the understanding it may need to be replaced/reconditioned shortly.
    2000 S3 APY
    Sep 2011
    Hi there,something to think about are the tyres. I had my car in for a wheel bearing change yesterday as the noise was a whine very similar to a wheel bearing from a ll speeds. The garage phoned back and asked why i thought i was a wheel bearing as they couldn't hear anything from either side. They phoned again after a road test and claimed two mechanics had checked and it was 100% the gearbox failing. I checked for gearboxes online and was thinking the same as yourself however a failing gearbox doesn't seem to be common fault so i went for a second opinion. Recently i had changed the replica 19" RS alloys for 18" with worn tyres and the second garage mechanic suggested that all the tyres on the 18" wheels were ruined and were causing the noise. I changed them back to the 19" wheels last night and hey presto no noise. Just a suggestion before you go through the pain....
  1. Pre-facelift S3 Gearbox Swap
    By Routledge in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th November 2011, 12:49
  2. Gearbox Swap Q's
    By Rallyman in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th September 2009, 23:18
  3. GEARBOX SWAP HELP!
    By A3Quattro1985 in forum General Technical / How To
    Last Post: 9th January 2009, 19:48
  4. TDI gearbox swap
    By awmw in forum General Technical / How To
    Last Post: 11th May 2008, 00:54
