    Aug 2013
    26
    Still having idle problems... please help me ...
    Hey, I have a audi a3 1.8T as some of you already know..., Not when i got it had a idle problem, was jumpy (only slightly) and when you rev it it will rev down as normal but drop down too low .. and the engine sounds as if its struggling for a second and will rev back up to normal idle and jump around a lil bit...
    Now before i changed anything it had a atmospheric dv - Now removed due to high recommendation from you lovely peeps :-) And now i have fairly good boost, Ive never had a 1.8t so no idea what sorta boot to expect but if you plant it in first it can spin up easily but other gears seems to be smoother boost ... Is that how its ment to be ?
    Ive swapped out the MAF for a new one also as there was a maf error code.
    Now it also had a itg induction kit which was pretty torn up so ive swapped that out for a cone filter i had lying around (brand new) as it never came with the original air box.
    I've also switched out the sparkers for some cheapy ones (I know prob a bad idea to start with ... but dont want to spend loads untill i know why its doing this) They are the 4 prong sparkers which were recommended to me by a golf mk4 1.8t owner.
    And also i topped up the oil which was running low but since ive noticed a clicking sound coming from the coil packs area... almost like a tappet sound... but isnt loud enough to be heard with the bonnet down ?? which before its said is not the the clicking coming from the carbon filter thingy as thats clicking away too lol... very similar sounds actually.
    Now i appologise for the essay but thought id start the threat with all my symptoms and what ive dont to try and solve it so i could get some decent advice rather than guesses due to not enough info on my part :-)
    Aug 2013
    26
    AUG Engine by the way if that matters in some way
    matt blowen's Avatar
    Jul 2013
    staffordshire
    111
    Add matt blowen on Facebook
    Does your car get up to temp? I mean needle sits at 90? That ticking sound is normal
    Jul 2013
    staffordshire
    111
    Also check for vac leaks and intake leaks after MAF
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,115
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Plug her into VCDS and see what's occurring.
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
  1. Still have an account problem - please help!
    By Mr.G in forum Site Support & Announcements
    Last Post: 5th April 2011, 17:21
  2. Major Problem Please help!
    By A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th February 2007, 17:25
  3. Cabriolet Roof Problem - Please Help!
    By StuartC in forum Classic Audi Forum
    Last Post: 8th July 2006, 20:22
  4. Brake Problems - Please help
    By technics100 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th April 2006, 23:00
  5. S3 Instrument Cluster Problem - PLEASE HELP !
    By imported_G123 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th November 2004, 08:03
