Chris NottJMB Retrofits
    Aug 2013
    37
    How do I reprogram my key
    Hi all I need to reprogram my a3 key on my Quattro how is this done?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    Aug 2013
    37
    Hi i dont want a spair key i have both orignal ones but i just need them reprogramming as they seem to have lost there info is it possible to do from the car
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    Be more specific as there are two operations involved here... there is unlock/lock and immobiliser... if its just unlock/lock then a search would have found you this thread on re-syncing key fobs (assuming the batteries aren't dead)
    have i broken my key fob?
    If the car won't start due to immobiliser kicking in then that a reprogramming job and requires special software hence linking you to the group buy as the guy running this re-programmes keys..
    <tuffty/>
    May 2012
    RETFORD, NOTTS
    1,748
    Had a non syncing remote a couple days ago, think it was due to a databus error, couldnt clear the old remotes out to code the new ones. There had been some wiring done recently so that needs looking at.
    where are you from smithy i could test and replace your remote if you need it and are local.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
  1. How to programme your audi key fob ( Instructions )
    By shawshankuk in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th November 2008, 20:38
  2. How to get the removal keys out of a Symphony?
    By wellhouse0 in forum In-Car Entertainment
    Last Post: 16th April 2008, 08:00
  3. How to program my new key?
    By DjDiddles in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 14th August 2007, 20:35
  4. How do i Reprogramme my Key fob??
    By H17E5H in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2006, 12:02
  5. 56 just to reprogram my key fob!!!
    By TDI in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st March 2006, 13:22
