Thread: Fuses
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    185
    Fuses
    Hello. I've looked and looked on the net to try and find the answer to my question, but no luck.
    Do any of you know which fuse is the constant 12v from battery to radio to hold memory?
    I've used to multi-meter on the yellow wire and there is 0v constant so I'm assuming I've got a fuse blown somewhere.
    Thanks in advance
    Dec 2011
    140
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    185
    Thanks! I'm assuming that the 12v constant to hold memory has it's own fuse somewhere, inline? Because the stereo works, but when I take the keys out of the ignition and then restart the car, the memory is lost. (this 12v isn't depicted in the fuse diagram above)
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    185
    I have just belled out the connections and found that Audi actually use different colour wires than most other car manufactures.
    To clarify, Red holds the +12v constant while Yellow holds the +12v ignition supply.
  1. Has my Concert blown a fuse ??
    By SteveDickinson in forum In-Car Entertainment
    Last Post: 8th August 2007, 09:16
  2. Haldex Fuse
    By JamesA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th May 2004, 08:47
  3. S6 fuses
    By paldridge in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd March 2004, 22:23
  4. Anybody know which fuse powers the ECU?
    By Ess_Three in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2004, 14:04
  5. Dashboard Display Fuse Problem
    By Jag in forum Classic Audi Forum
    Last Post: 4th December 2003, 16:18
