AH FabricationsBadger5
Page 1 of 2 12 LastLast
Results 1 to 40 of 49
Like Tree5Likes
Thread: Advise on s3 mods please peeps!
    Aug 2013
    22
    Wink Advise on s3 mods please peeps!
    Hi all just recently bought a 2000 s3 in Ming blue.
    Standard other than panel filter recirc valve n a (smooth map).
    thinking of getting
    exhaust system, been looking at full milltek systems any advise ? Better value for the money ?
    Fmic noticed there's a company doing them on here for £379 plus pipe work ? Any good.
    also some pipe work : tip etc
    Anyone got these mods and tell me what gains ?
    been told to change turbo but if I can get 300 on standard ill be happy.
    also anyone done a clutch ? They much of a ball ache never done a s3 before , Think ill need to do one soon.
    cheers guys
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,640
    Hi and welcome to ASN! Here's a few things to read, best to read it in full! A3/S3 FAQ / How To's / Tuning Info STICKIES - PLEASE READ BEFORE POSTING
    Aug 2013
    22
    Hi buddy thanks yea just read through was handy was just a bit more interested in personal experiences with parts , fitting and gains noticed a lot of people changing Rods ? They a weak part on these you know ? Thanks con
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,082
    Visit 16Klappe's Instagram Channel
    Try the bar on the top right, think it says search?
    Those FAQ's and stickies are all written by owners and forum members so.they are totally personal and unbiased opinions.
    Rods on 1.8t are not weak by design, but once you start ramping up the torque and power they become a concern. It is all down to pot luck, what you want from the car and internal factors which nobody could tell.
    I quite often say I'm going to do things.
    Then never do them.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,606
    Quote Originally Posted by Connors3 View Post
    thinking of getting
    cheers guys
    Hi and welcome to ASN...
    As said, you should have a look through the FAQs thread in the stickies as this has links to a load of threads discussing the sorts of things you are after...
    ...but in summary...
    Exhaust system won't give much in the way of gains as such as its not much bigger than OE... better off looking at a 3" DP and sports cat for actual gains... OE DP and cats are restrictive and can create high EGTs hurting performance...
    The FMIC you are on about is the AH Fabs V2 and is an excellent FMIC... is running on 400+ hp cars and easy to fit... there is a FMIC thread in the stickies, I would advise you to read it
    The best TIP on the market is the Badger 5 80mm TIP... has been proven to give up to 18hp gains as a bolt on some cars...
    As for 300hp on a std K04... this has been done but... and its a big but... its hugely subject to supporting mods and condition of engine/turbo etc... Westy (search his user name and read his thread) has achieved this but he had a new turbo and all the bolt on mods (including a large port head) you can get... Badger 5 recently had an S3 in that produced 295hp using a std K04, AH Fabs V2 FMIC, Relentless exhaust manifold and B5 TIP...
    You would also need to consider injecters as OE ones max out around the 280/290 mark... this level of power is not achieved by the turbo alone, timing advance plays a key part in this level of power as the K04 will not flow best part of 300hp alone...
    If you want an easy 300hp then get a hybrid...
    You will also need to get a proper custom map... generic ones will not cut it
    <tuffty/>
    Aug 2013
    22
    Thanks for all your help guys , I did read about the cooler and power just looked at down pipes n de-cats there not cheap for these ay ! Been thinking its look either bassicly go all out ie turbo, injectors , full system , tip , custom map n fmic or don't bother.
    been thinking might go a diff route just get a cat back so it sounds a bit better then just do visual parts ie wheels , possibly tints , spray a few bits.
    Would you recommend the badger 5 tip is worth just putting on as I read its common for original to collapse under pressure even with just stage 1 mine this would shorley only help and maybe have minimal gains.
    Thanks again Connor
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,283
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    + rods... (and everything else that will need replacing like fuel pumps, coil packs, various other hoses! lol
    Thanks again Connor
    Everyone recommends putting a larger TIP on - especially a B5. Not to sure where you saw/heard it will give you minimal gains? The amount of R&D does not suggest this at all....
    As mentioned in the first post by Gops above, have a little read through here about specific stuff you want to do -
    Then if your finding that long winded use the search bar in the top right...l.
    Oh and welcome to the money pit
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    Aug 2013
    22
    Mean minimal gains if I'm not doing other supporting mods mate ie ill just have : cat back - panel filter - recirc valve - tip - stage 1 map,
    dont suppose any of you guys know anyone selling a cat back system ? Looking at milltek ones non resonated not expecting many gains really if any as obviously the cats and dp are the main restriction just want it to sound better , also I know slightly off topic any of you guys know what fog light bulbs ill need currently in Greece and can't check but wanted to order some cheers again
    kwistof's Avatar
    Jun 2010
    SE Kent
    2,283
    I reckon you will get more gains from a B5 TIP open cone filter with heat shield, than just a Milltek cat back exhaust (non res). Both resulted in glorious sounds though
    TIP gains have been talked to death on here- have a search and read up...yes you will see gains by just changing the OEM TIP to a B5 one without any other mods....yes you can run it without being mapped....and yes the best thing to do is get a TIP on first and then stage 1 custom remap....
    There is a classified section in here you can look through to see if anyone is selling a Milltek.....as they are regarded as the best cat back system for our cars then they don't hang about for long and usually go for good money.
    2000 S3 APY
    Aug 2013
    22
    Hi buddy yea It all ready has a stage 1 remap was done by previous owner so would ideally map again and cheers just messaged a company regarding tip be gettin next week hopefully and I have looked and as you say cat backs are hard to get let alone cheap might just get a new one no faffing about then cheers for your help mate
    kwistof's Avatar
    Jun 2010
    SE Kent
    2,283
    I'm in the market for a Milltek non res very shortly for my S3 and I've been looking everywhere....(for a new one)
    AMD Essex (forum sponsors) seem to have the best deal for the part inc fitting.
    Milltek Sport Cat-back {Non-resonated (louder)} for Audi S3 210 quattro 1.8T
    btw no worries, this is what a forum is all about
    2000 S3 APY
    Aug 2013
    22
    Yea good to be on a forum where everyone actually helps everyone out and yea I have a place just near me (amd) I did look I'm a mechanic so I'd fit my self noticed they do either 10%off or free fitting so that will save me approx 55 going to ask them about there map as my current map was done by c g remaps not a company I am familiar with drives smooth so going to put tip and exhaust then prob get amd to rolling road it then if there map will make a difference I will buy that think best way to do it is go up and have a chat with them cheers con
    If enough people interested in cat back's could maybe try a deal with them I know it's 10% off but £1600-1700 pounds of exhaust must have a little more negotiating
    May 2013
    Channel Islands, Jersey
    82
    nice little thread.
    I bought a badger5 tip with filter and heat shield. Made the car respond a lot better, as well as making it a lot louder. Great buy! highly recommended.
    I've been looking into a milltek exhaust and this seems like a great deal. Shame they don't have a base in Jersey for the fitting and then potential rolling road!
    Aug 2013
    22
    What filter did you get buddy ? Been looking and aparenatly a panel filter gives best gains which I have was going to smooth air box to assist this but yea just looked again and getting an intake hose next week so hopefully see gains then I see the air filter and heat shield you mean it's approx extra £100 would you say would be worth it ? Just thought that's 5th price towards exhaust and in past open air filters normally have caused a further lag point to my vehicles you noticed this on your s3 ? Thanks mate
    May 2013
    82
    Alright mate, I got the JR air filter. I am a newbee here too. But when scrolling through all the previous posts etc its well argued that a cone filter gives the best results. They all talk about an OE S2000 one being the best. To make it easy for me, I just got the one that Badger5 sells. Everyone rates him on here and he seems to know his stuff, if you read his comments etc that he leaves.
    Im sure like any mod, there will be positives and negatives. So far i am very happy with it. My car seemed to have more of a lag with the OE system. It definitely pulls a bit harder now, but it also sounds a lot louder. Including wind up and let off. My OE DV makes a lot of noise now, where it was very silent before. Bottom end you can hear the usual purr of a cone filter, which is nice.
    If anything everyone suggests it as your first mod, and cars upto and beyond 300bhp seem to have one of these TIPS.
    I will eventually put a car thread up!! with vids on.
    Aug 2013
    22
    Yea well I'm going to get the tip fit that then I think ill get exhaust and prob end up with the filter after exhaust , been looking more and more at front mounts as a lot of people on here saying they are not man enough really after remap and any mods , in a big debate alone of talk of ah fab ones also there is a kit on eBay for universal intercoolers (think they have one in classified ads) was gonna see if anyone had got an eBay one if so how rated
    Mar 2013
    45
    Hi guys,
    the front mount intercooler you want is the 'wellycooler'. This is available on eBay, made by toyosport. It measures 600x300x76. Hope this helps
    Aug 2013
    22
    Have you got any personal knowledge on this cooler buddy ? And is that the £375 one ? Thanks Connor
    Aug 2013
    22
    Iv noticed all except forge which comes with adapted slam panel needs the slam panel grinding away slightly for fitment so didn't wanna go through any hassle to then get a pants cooler if ya get what I'm saying mate thanks
    Mar 2013
    45
    Yes, you need to cut the crash bar. I've just fitted mine. The link below doesn't come with hoses and pipe work but if you do a search in the stickies for the 'fmic' thread it will tell you exactly what's needed. The cheapest place to order pipe work and hoses from is 'ash' (auto silicone hoses) which are also on eBay. http://bit.ly/R75y6P
    Aug 2013
    22
    Oh that's cheap ! How much did your hose and clip kit cost as the kit I was looking at was £375 complete also you noticed difference from the cooler mate ? What other mods do you have and also how do they fit under bumper not in a funny way but do they look pants because of the slam panel being slightly modded or once there tucked up look oaky ? Cheers
    Mar 2013
    45
    They look fine. You need to have a read through the stickies at the fmic thread and it will tell you everything you need to know. I will post the link in a minute. Do plenty of research and you'll be fine
    Mar 2013
    45
    My phone won't let me copy the link to here! Either give me your e-mail address and I will send that way or use the search bar at the top
    Aug 2013
    22
    Cheers mate ill save yu hassle and go through the fmic threads , cheers for all your help
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    right, i see alot of deliberating, wild claims and terms like 'lag' used for filters and tips lol, and is it really worth it over an exhaust.
    To clarify, a cat back exhaust will net you absolutely 0bhp, and 0 extra smiles. Dare i say it, it will prob sound not much greater than stock if you have the oem cats and downpipe system on there, that is the restriction, that is the part of the exhaust that offers the most 'bang for buck'. Id seriously advise against adding a miltek if you are looking for extra sound and power.
    Basic bolt ons, in order of their 'bang for buck' are as follows:
    A B5/80mm TIP with a cone filter OR panel filter. The filter is preference but you WILL see more powerz with a large cone.
    3'inch downpipe and decat/sports cat - oe system is stupid, seriously restrictive, and on mapped cars that are driven hard, will see high egts and sap power.
    Last Is a fmic (intercooler) - same reasons as the downpipe, better heat management, more available power/response.
    /end
    Jersey likes this.
    Nov 2004
    39
    "fitting and gains noticed a lot of people changing Rods ? "
    Hi
    No need for new rods or anything else really.
    A Milltek will last and last and makes quite a noticeable difference. I went for a resonated system, so it is not too loud until it is nice and warm and over 3500 rpm
    I have been running a Jan 2003 S3 since 2005 with stage 2 tune, Milltek, Forge DV with no problems and the power is not far shy of 300bhp (or wasn't when we did all the work 70,000 miles ago )
    No problems at all with engine or drivetrain until this MAF packed in recently not linked to tuning)
    The only thing i did to improve longevity was to make sure it has a service every 10,000 miles rather than the variable service routine
    Been driven hard too )
  28. #27
    Aug 2013
    22
    Hi so you got forge valve - full milltek - map yea who did your map buddy I keep looking on eBay trying to see if any cheap de cat's n down pipes are going here are a lot of cheaper ones not sure weather to get a 3" cheaper one the cat back milltek or get a milltek de cat back then wait for a down pipe to come up and get a stage 2 as l will have the badger 5 tip then aswell and hopefully a fmic still I. Big debate which one to get :/ cheers con and has your been rolling roaded , bit of topic was surprised how good they are on top end mine as stated just has panel forge valve n map n I had 150 n was still goin for a Quattro I was quite surprised to be honest (obviously on private land)
  29. #28
    Aug 2013
    22
    330968108633 found this down pipe and de-cat on eBay anyone used one before ? Thinking this to a milltek cat back ?
  30. #29
    Aug 2013
    22
    261155508934 that was the cooler I was looking at and a lot have been bought so now either that or the one above that Matt said about
  31. #30
    vivalacoulter's Avatar
    May 2013
    S. Wales
    200
    Follow vivalacoulter On Twitter Add vivalacoulter on Facebook Visit vivalacoulter's Instagram Channel
    Hey that doesn't look too bad! Little short though perhaps?
  32. #31
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    My post was ignored, and you opted to listen to a guy who had his car 'tuned' back in the 18th century who thinks he has a stage 2 with only a miltek 007p and 300hp.
    Good luck...
    Dani_B19 and dancuz like this.
  33. #32
    Aug 2013
    22
    I didn't ignore you buddy I added these links for advise from people I am getting a tip next week and using a penal filter currently and I added the fmic and de-cat to see if anyone has used them and advised using them or genuine makes ? Cheers for ya help mate
  34. #33
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,082
    Must. Log. Off. Before. Red. Mist. Descends.
    Must. Not. Get. Banned.
    Again.
    superkarl and Jason.s like this.
    Then never do them.
  35. #34
    Feb 2012
    Rutland
    132
    Quote Originally Posted by Imola View Post
    I'd be suprised if you netted 250 on proper rollers. This is the best thread I have read in ages!
    2001 AMK S3 in Goodwood Green
  36. #35
    Sep 2010
    Devon
    756
    All I'd say is that if your constantly looking for everything to be cheap then you seriously have the wrong car, it all costs more than a lot of comparative cars and if your going to do it, do it once and do it right. Go big or go home and all that
    Badger 5 tuned 340 bhp / 350 lbft sleeper
  37. #36
    Aug 2013
    22
    Yea I noticed proper parts are not cheap aha , I will properly end up gettin proper stuff just thought no harm in looking and if some kits / parts do the same job it's a win win situation save a bit and still gain some stuff iv just gone straight to proper parts eg tip but as there are so many different fmic and exhaust systems I was just see what is to offer really sorry if anyone getting annoyed for any reason but way I look at it this forum is for people to help each other so if someone saying would this be good if someone only uses branded parts then that's up to them. As said I am very pleased for all inputs there all helpfull and I'm air either user's scroll through and I'f maybe they can get for example a fmic kit for £350 ish that's as good as a £800+ forge then that's just saved £500 so that's how I look at stuff . DON'T KNOW UNTILL YOU ASK ! But thanks again everyone
  38. #37
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,283
    I have a real 300bhp and it has a lot of mods, a full custom map, a lot of new parts, and a lot of time and money has been spent to get it. Oh and I still have the stock DV
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  39. #38
    Feb 2008
    2,817
    Westy, after being in gopals your must be very very quick!
    2000 AMK S3, Revo'd, forge 007p, B8's, H&R's, tarox g88's, ferrodo ds2500's, and in the fastest colour
  40. #39
    Westy's Avatar
    Dec 2008
    17,283
    Quote Originally Posted by S3 Rav View Post
    It's a lovely drive compared to the old punchy revo map but unfortunately I don't get to drive it as much as I'd like to.
    S3 Build Thread
  41. #40
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,640
    That's one car I wanna go in -westy's! Love to see the difference! I thought mine was quick, that must be pretty mental!
  1. Red A3. Exterior mods please!
    By Huz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th March 2011, 19:58
  2. MODS PLEASE READ - stickies
    By bantam1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st August 2009, 13:46
  3. advise for a newbie please
    By chris@yoco in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th February 2009, 19:07
  4. Need some advice please peeps. :(
    By Herby1 in forum General Chat
    Last Post: 22nd November 2006, 22:34
  5. Need advise with my S3 please!
    By Performance in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th July 2003, 08:40
