Badger5Volks Autos
Results 1 to 8 of 8
    S3 TAM's Avatar
    Pocket now empty
    Oct 2009
    London & Hertfordshire
    621
    knock sensor 2 issue's
    Hello All,
    I'm back after not posting for some time. Just been enjoying the S3 until now.
    For the past few months i've been getting VCDS error
    16717/P0333/000819 - Knock Sensor 2 (G66): Signal too High
    Possible Symptoms
    • Engine Damage
    Possible Causes
    • Knock Sensor 2 (G66) improperly torqued
    Possible Solutions
    • Torque Knock Sensor 2 (G66) to specifications
    • Check Knock Sensor 2 (G66) and Knock Control
    I tried every thing the vcds wiki page has said from checking the torque to replacing the sensor this leaves one thing left
    ENGINE DAMAGE
    What could this be? something in the bottom end about to give up?
    Is it time for me the put the large port head on the motor that i've had sitting in my garage for 1 1/2 years?
    this brings me to my next question which i think i already know the answer too. "don't shoot me down for this"
    Would you buy this off ebay
    for Audi S3 A4 TT 1.8T VW Golf Gti Con Rod Conrod H-beam Connecting Rod Rods ARP | eBay
    Money's tight at the min saving for a house and a wedding... silly me i know, but if im gonna change the head i might as well do the bottom end or vice versa.
    cheers in advance.
    Revo Stage 2 with all the Gear
    BHP = 274 / Torque = 293
    S3 TAM's Avatar
    Pocket now empty
    Oct 2009
    621
    ohh forgot to ask would running a large port head on standard rods be ok?
    if money wasn't an object hey.
    S3 TAM's Avatar
    Pocket now empty
    Oct 2009
    621
    Just found a post from tuffty
    which i haven't tried. i hate wiring.....
    VAGCOM - Knock Sensor problem
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,575
    Quote Originally Posted by S3 TAM View Post
    Haha... yeah, one of my first posts as a n00b 4 years ago lol... all have to start somewhere
    Re-wire worked for me... its not as bad as it looks as you can just run the new cable along side and patch in...
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,575
    Those rods aren't rifle drilled so tbh I wouldn't touch them personally... I would also not bother with a large port head unless going north of 350hp...
    <tuffty/>
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    879
    Add Vex182 on Facebook
    I've got the same code but in knock sensor 1 at the minute, I'm hoping its just a loose sensor and not the cable. For the first 30 seconds of driving, the car feels rough and underpowered but then disappears and the car drives great! If the car is up to temp then the car drives complete fine when restarted, I guess it is related to this one code.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,575
    Quote Originally Posted by Vex182 View Post
    Yeah, if the ECU thinks it can't see knock as the sensor is playing up or if the signal is not as expected then it will pull timing out and you will lose torque...
    <tuffty/>
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,275
    Saving for a house and a wedding.
    she'll murder you!
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  1. Knock Sensor 2.8q 30v
    By dsmclark40v in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th May 2007, 10:03
  2. KNOCK SENSOR
    By vw754 in forum General Technical / How To
    Last Post: 30th March 2007, 15:54
  3. KNOCK SENSOR
    By vw754 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th March 2007, 10:24
  4. Parking sensor issues
    By dan1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th April 2006, 09:32
  5. What can knock a knock sensor?
    By MisterD in forum General Technical / How To
    Last Post: 20th May 2003, 13:53
