Results 1 to 11 of 11
    Jun 2012
    289
    Drivers window issue - Help please
    Hey all,
    So, driving back from the In laws house and put my drivers window down. It decided to go about half way down and stop. I tried to make it go down again, and it went slightly up, then all the way down. And stayed there.
    The motor makes a noise, but not a constant noise when the finger is on the button, more it kind of ticks on and off a couple of times.
    To make matters worse the bloody heavens opened, so I got soaked whilst taking the door card off, subframe off, disconnecting the bottom clips off the glass, and jamming it up with a screwdriver!
    Im guessing it's the motor gone kaput, none of the cable had come off or snapped. Any ideas?
    2001 S3 btw.
    Cheers guys!
    Jun 2012
    289
    And before somebody says 'stickies' that the first place I looked and thank god I did! A great guide on dismantling the door in there!
    vivalacoulter's Avatar
    May 2013
    S. Wales
    194
    Follow vivalacoulter On Twitter Add vivalacoulter on Facebook Visit vivalacoulter's Instagram Channel
    Very strange! Mine did a similar thing when the seal around the window was very dry and it began getting stuck on its way back up... Just changed direction!
    If I were you I'd replace the motor and then invest in some silicone lubricant spray for the window seals and around the window. I just ordered some off eBay for £4.99, bargain!
    Big Al's Avatar
    Engine knackered!!
    May 2011
    West Midlands
    302
    Quote Originally Posted by Nogmeister View Post
    Yes, it'll be your motor. I have a working motor, regulator (the frame it all sits in) plus glass if you need it, selling on Ebay -
    Audi S3 8L facelift breaking spares Recaro seats interior TT Quattro Golf Mk4 | eBay
    Ebay message me for details & prices
    Alistair
    Audi A4 B7 2004 red 2.0 TFSI Quattro Sport saloon, Servotronic steering, MFSW, CDIS, DRL with Coming Home, auto dual xenon lights/wipers/mirrors, split folding rear seats, 3rd headrest, centre armrest, Isofix mounts, RS4 rear ARB, pedals & carbon dash trims; Audi TTS 9Jx18alloys (2 sets), Yokohama AD08 summer, Conti TS830P winter 245/40/18 tyres, TPI 15/20 spacers/lockers, Pipercross filter, GFB DV+ turbo valve, NGK BKR7EIX plugs, Osram Silverstar Xenarc D1S bulbs. Build thread
    Feb 2012
    358
    Quote Originally Posted by Big Al View Post
    Alistair
    Hi, this is strange, one bigal after another. I had the same problem, no cables snapped but since the cable is multistrand it is prone to the outer wires becoming broken The wire passes through a metal tube and it can jam if the outer wires have broken. I bought a second motor to no avail, then discovered the frayed wire. The wires are available on ebay for about £20.00 if this is the cause.
    Jun 2012
    289
    Cheers Big Al's! Hopefully will sort her this week!
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    It could also be some plastic clips in the window themselves that can snap, they are about 50p each, if you do a search there will be info on it as its a common fault.
    Jun 2012
    289
    Yeah it turned out to be the clips in the end, got the newer pink ones from Audi for £7.82.
    If anyone has similar issues, drop me a PM :-)
    Cobra88's Avatar
    Sep 2011
    Live in Ipswich Suffolk (orig from W London)
    435
    My Passenger window did the same thing over weekend
    So easy to fix with the whole thing out of the door
    Regards
    Rick
    2004 Audi A4 (B6) 1.9Tdi 130 Sport (6) Avant in Dolphin Grey.
    18" S4 AVUS, RS4 Rear Roll Bar, Leather Alacantra Sport Seats, Shark Performance 170 Remap,
    BOSE, XtronsA4A double din, Full DIS, Autolocks & Alarm Chirp.
    Avant Sport 1.8T Valance with twin exit.
    Nilz's Avatar
    Apr 2006
    10,087
    That was a nice cheap fix then hey??
    Jun 2012
    289
    Yeah bargain! Glad it was cheap too. Plus I liked the way Audi designed the door with an unboltable sub frame, made the job a lot easier than when it happened on my Mk 3 Golf!
  1. Passenger Electric Window Issue Help Please
    By Adam P in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th June 2013, 18:28
  2. RNS-E mk2 Coding Issues - Help Please!
    By Avus Sportback in forum Satellite Navigation
    Last Post: 27th August 2011, 12:39
  3. Wishbones and ARB issues... Help please!
    By Curt in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st August 2010, 19:35
  4. B5 1.8t running issues! Help PLEASE!
    By s11pyk1234 in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th September 2009, 00:12
  5. Window Guide help please
    By LaSarthe&Back in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th June 2008, 13:44
