JMB RetrofitsChris Nott
Results 1 to 11 of 11
    Nimosonen's Avatar
    Jul 2013
    Norway
    68
    Gas gauge problem
    Hey guys. My gas gauge is showing me wrong all the time. When I fill my tank up, it indicates 5/4 gas. And it stays there for like 200km. When I have 1/4 tank left, the fuel warning lights comes up. What can be wrong?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Fuel tank sender I suspect.. any fault codes?
    <tuffty/>
    Nimosonen's Avatar
    Jul 2013
    Norway
    68
    I don't have acces on VAGCOM, so I don't have any codes. Is it possible to change the fuel tank sender?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    I believe this is available as a separate part... you need to take the fuel pump out though as its attached to that...
    Westy has done a fuel pump swap...
    W3STY's Progress Thread
    <tuffty/>
    Nimosonen's Avatar
    Jul 2013
    Norway
    68
    Thank you mate
    Nimosonen's Avatar
    Jul 2013
    Norway
    68
    I've done some research, and it seems like the sender and the pump are 1 unit.. The pump costs 300$..
    phil miller's Avatar
    Sep 2012
    Devon
    843
    does the speedo work?
    ​Wish Rachel would let me have my TDI mk5 back
    Nimosonen's Avatar
    Jul 2013
    Norway
    68
    Yes, everything else but the fuel gauge is working
    Sep 2012
    Devon
    843
    check the fuses and if all is good, check the gauge when manually moving the level float, if still not working then it needs replacing
    Nimosonen's Avatar
    Jul 2013
    Norway
    68
    How can I manually move the level float?
    Nimosonen's Avatar
    Jul 2013
    Norway
    68
    I've uptained that I get low fuel warning light when I'm almost empty. The gauge is showing 1/4 of a tank still. Is there a good reason for that? Seems like the sensor is working fine, but its just showing wrong in the dash..
  1. Fuel gauge problem!?
    By POC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd March 2008, 09:46
  2. Fuel Gauge Problem
    By Nilz in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th February 2008, 16:24
  3. fuel gauge problem
    By stapo69 in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th March 2007, 20:52
  4. Fuel Gauge Problems
    By jpeterman in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd October 2005, 21:37
  5. Fuel gauge problems !
    By S3LAK in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th April 2003, 08:20
