Volks AutosMonster Motorsport
Thread: engine help
    May 2011
    Manchester
    engine help
    I recently bought an s3 but the bottem end has a
    big hole in it iv took the head off it and it has 3 bent valves but is repairable I was
    just wondering dose any 1 know if the bottem end off a aum engine out of the a3 1.8t
    will fit the head off the amk s3 engine and go straight back in with no problem
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Don't use an AUM bottom end on your S3... yes it will fit but its weaker... AUM's use 19mm sintered crank rods and tangless bearings... not really suitable for an S3 bottom end tbh...
    You want to look at any of the 210/225 VAG engines (TT, LCR, S3) or an AGU bottom end...
    If its just pistons you need I have some S3 ones I can do you a decent deal on if you drop me a PM
    <tuffty/>
    May 2011
    Manchester
    cheers tuffty tink the agu will b the better option then as no 1 wants to break an s3 engine
    I would prob get 1 cheaper aswell thanks for the offer on pistons but needs full bottem end
    big hole in the side of block and 1 in sump he made a mess lol
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Quote Originally Posted by Brogzi View Post
    Ah.. yeah, that would do it... if you had been quicker you could have bought my old bottom end off me :P
    <tuffty/>
  1. a4 engine help
    By jimmy77 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th August 2010, 18:49
  2. Rotor hat -> spacer engineering help
    By random101 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th February 2010, 13:17
  3. Engine Help
    By N80KRR in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th January 2010, 16:27
  4. In Search of New Engine - Help Required
    By Burnhamhurst in forum TT/TT-S/TT-RS Forum
    Last Post: 30th March 2008, 18:02
  5. DBZ tranny on 1.8T AGU engine - Help?
    By Feik in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2007, 23:49
