Sky InsuranceChris Nott
Results 1 to 22 of 22
    Repooh's Avatar
    Aug 2013
    23
    Cool Re-build of audi 1.8 enine
    What's good fellas. I've just joined up and want some knowledge from you guys. I have re-built my 1.8 t engine after having blue smoke bellowing out the rear. I found out that the piston was absolutely effed. So I replaced it and put it back in. Now the starter motor isn't engaging with the flywheel? I've asked other vag owners and I've been told its the earth wire. Where would this be?
    beachbuggy's Avatar
    Surrey
    1,727
    under the battery
    Repooh's Avatar
    Aug 2013
    23
    Where should I connect it to. I'm not too good with electrics better with engine mods. Cheers
    Repooh's Avatar
    Aug 2013
    23
    Where would I put it
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    There should be a thick earth cable coming from under the battery tray that connects to the head of the top bolt fixing the gearbox to the block... it will be the one towards the front of the car rather than to the rear...
    You can see it in the pic below...
    <tuffty/>
    Repooh's Avatar
    Aug 2013
    23
    Ok cool mate I'm going to have a look now. If I get stuck I will give you a shout.
    Repooh's Avatar
    Aug 2013
    23
    I can't see it lol. Anyway you can highlight it. Sorry mate
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    Quote Originally Posted by Repooh View Post
    Circled in red...
    <tuffty/>
    Repooh's Avatar
    Aug 2013
    23
    Nice one brother
    Repooh's Avatar
    Aug 2013
    23
    To. I done that but it's still spinning freely. Could the starter motor need adjusting to fit in? I'm bugging out can you help
    Scullies's Avatar
    Feb 2012
    Dubai
    1,208
    Sounds like it might be the solenoid. I would take it out and clean all the contacts, bench test it too.
    Repooh's Avatar
    Aug 2013
    23
    When you say bench test it what do you mean?
    Scullies's Avatar
    Feb 2012
    Dubai
    1,208
    Apply 12v to the solenoid/motor to make sure its working correctly. Hold the motor down as it got a fair bit of torque.
    Repooh's Avatar
    Aug 2013
    23
    Solenoid works but still won't engage. Still spinning freely? What else could be the problem?
    Scullies's Avatar
    Feb 2012
    Dubai
    1,208
    Did you put the flywheel on
    Or did you change the flywheel and its not the correct one?
    Repooh's Avatar
    Aug 2013
    23
    Yeah of course but its making a slight knocking sound now. What could that be? I'm pretty sure everything is connected properly. It's just bugging me because it started fine with a @#*¥ed piston!
    Scullies's Avatar
    Feb 2012
    Dubai
    1,208
    Have you checked the voltage at the starter motor?
    Can you turn the engine over by hand?
    My only other suggestion is the motor doesn't have the balls to turn the new engine with the new compression. Try taking the plugs out and see if the engine swings over without any compression.
    Repooh's Avatar
    Aug 2013
    23
    No haven't got the equipment to do the voltage.
    Yes I can turn it over by hand.
    Maybe. What do you men by swim over? When you turn it you can hear it moving properly.
    Scullies's Avatar
    Feb 2012
    Dubai
    1,208
    Maybe you not getting full volts to the starter. You need to check that.
    without the spark plugs in there will be no compression in the cylinders as the engine cranks over, so less strain on the starter.
    Also disconnect the injector plugs and leave the coil packs out too.
    I doubt this will be the issue, but I'm all out of ideas
    Repooh's Avatar
    Aug 2013
    23
    Ok cheers mate going to try that 2m
    Repooh's Avatar
    Aug 2013
    23
    The battery was basically dead aswel would that be a factor because this car started with a big of throttle with an effed piston? So I don't get it! Is there anywhere that I can get electrics diagram for this model.
    Repooh's Avatar
    Aug 2013
    23
    Got the starter working. But still won't start. Had mechanic have a look and valves are shot from trying to jump it with hardly any oil in it. Effed sake. Where can I get valves from
  1. Big Red Building and Little Red Audi
    By technics100 in forum Photography & The Digital Darkroom
    Last Post: 3rd July 2008, 00:23
  2. Replies: 5
    Last Post: 16th January 2007, 19:21
  3. Any good resources for Audi build process info?
    By A3_TOBES in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th September 2006, 13:32
  4. Acceptable Audi build quality?
    Last Post: 28th July 2006, 08:25
  5. Audi 80 as donor car for build project
    By larsdahlberg in forum Classic Audi Forum
    Last Post: 23rd July 2006, 19:04
