AH FabricationsSky Insurance
    Nov 2012
    Traction off permanently and power gain??
    Driving home, I usually turn my ESP off, but this time it was off, even if I press the ESP button it would not turn on, suddenly boost went in early, power was amazing ! Night and day difference than my previous drive with the ESP off, should I be worried?
    Also the aircon fan changes automatically, when I press 19 C, the fan adjusts automatically even if Auto setting is not lighted.
    Car is Audi s3 8l BAM engine.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    As in the ESP ligt was on all the time and you couldn't turn it on? this is normally a sign that the MAF is faulty... a scan for fault codes should be next on the list...
    The aircon thing sounds normal to me... as you adjust the temp the fan will normally speed up or slow down based on cabin temp, sunlight sensor and ambient temp... all auto does is maiantain the selected temp in the cabin by varying the fan speed and hot air (from heater matrix)/conditioned air ratio to 'climate control' the cabin temps
    <tuffty/>
    Nov 2012
    Will scan tomorrow tuffty thanks for the reply, I will post the results.
    A bit of a problem with the aircon, just replaced my compressor with a new unit, very cold when fan is 60% but losing the coldness and smelling weird when fan adjusts to 1 bar or 2..
  1. power gains from k04 and xs mani
    By jam333 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th February 2012, 23:53
  2. A3 3.2 V6 Traction Control Permanently off!!!
    By bigdog_olly in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd March 2009, 17:57
  3. problem with power gains after remap
    By shufti in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st June 2006, 14:09
  4. Drop in boost pressure and power :-(
    By HTC in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th November 2005, 23:07
  5. Leaking Hydro fluid and Power drain
    By imported_acklac7 in forum General Technical / How To
    Last Post: 3rd November 2004, 11:18
