Chris NottSky Insurance
Thread: Knocking 02J
    Feb 2012
    Denmark, Copenhagen
    199
    Knocking 02J
    I have posted in here several times about my issue with the 02J gearbox.
    Now i have a factory brand new 02J, and a new OEM clutch, and the issue persist. The old one had a hole in it.
    The symptoms are occasional knocking when going second gear, and a slight crunchy sound when going third. Both happen before i let go off the clutch.
    The sounds are identical to my old gearbox, and my gearbox doesnt feel "new", at all.
    Any ideas as to what this issue could be? It is literally sucking out all the joy from driving the car.
    Feb 2012
    Denmark, Copenhagen
    199
    Small update: I did a full linkage adjustment, and the knocking seems to have been greatly reduced. It still does it occasionally, but nowhere near as often as before. No idea why it does it to begin with.
    Mar 2013
    Devon
    562
    Have you checked your gearbox side and lower dogbone engine mounts?
    I had this problem, but after fitting a powerflex red diesel dogbone bush, new gearbox mount and setting up the linkage. shifts are now precise and drag free.
    Feb 2012
    Denmark, Copenhagen
    199
    I did change the dogbone a month ago. Didnt help anything.
  1. Knocking from the front during gentle braking ???
    By noodle in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2008, 22:29
  2. Knocking sound
    By recomdos in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd May 2004, 19:14
  3. (Rear?) Suspension Knock on S3
    By gdwood in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th November 2003, 19:05
  4. Knocking Noise
    By L1ARR in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th September 2003, 17:19
  5. What can knock a knock sensor?
    By MisterD in forum General Technical / How To
    Last Post: 20th May 2003, 13:53
