Volks AutosSky Insurance
Thread: ABS Problem
    Aug 2013
    12
    ABS Problem
    hey all got my first fault on my audi today
    I was having a nice steady drive home from work
    and i pulled over to run into the shop
    as i left the abs started making a noise
    then the noise stopped and the ABS light came on
    it wont go off
    so i left the car for 20minutes or so fired it back up
    great no light came on drove maybe 100yards
    light comes back on
    daft question but would having a warped disc make the light come on as
    it shakes a bit when i brake??
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,061
    Visit 16Klappe's Instagram Channel
    Yep.
    I quite often say I'm going to do things.
    Then never do them.
    Aug 2013
    12
    I've checked the 3 fuses on top of the battery look fine I replaced them anyway lights still on
    Though I really need to get the car plugged in
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,061
    Quote Originally Posted by ROBA3T View Post
    VVVV
    Quote Originally Posted by 16Klappe View Post
    Yep.
    Then never do them.
    Nov 2007
    49
    Mine did exactly this and the 3 30A fuses on the battery were the culprit. They didn't look too bad but had obviously got hot, cleaning up the contacts and replacing the worst (I only had 1 spare) cured it. Also cured my oil sensor fault for a little while, but thats re-occured so I'm guessing is one of the fuses I didn't change.
    Really depends on your fault code though, mine was showing "01276 - ABS Hydraulic Pump (V64), 16-10 - Signal Outside Specifications - Intermittent" and I think is the only ABS fault that can potentially be fixed with that simple trick - get your car scanned!
    Aug 2013
    12
    Fingers crossed I've fixed it got the car plugged in at a friends passenger side rear speed sensor came up
    So I have replaced it drove up the road light went out
    What a chew on to replace it i ended up removing the brakes and hammering it out that way it was stuck solid
    Never fitted one before 10minute job now I know how
  1. S3 Traction control/ABS problems
    By Daz A3 TDI 130 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th March 2011, 08:26
  2. ABS Problem
    By Pat in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd May 2007, 18:33
  3. ABS Problem
    By mwarrey in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th August 2006, 13:21
  4. Common ABS problems
    By chrisa4quat in forum Tuning
    Last Post: 3rd January 2006, 14:17
  5. urgent please help esp abs problem 02d900554b
    By imported_flava in forum General Technical / How To
    Last Post: 5th April 2005, 17:38
