Monster MotorsportEM Tuning
Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By 16Klappe
Thread: Induction To cone or not to cone ?
    Aug 2013
    36
    Hi all,
    I have just got an a3 quattro and was woundering if it is better to stick on cone filter on it or just replace the pannel filter with a good k&N pannel.
    Does this car bennifit from a cone or not i know some cars do not like it and run worse
    Gizmo20VT's Avatar
    Jun 2012
    289
    Hi SMithy
    There are several posts regarding cone filter, stock box, pro's and con's if any.
    Try use the search function and also browse over the stickes.
    Welcome to ASN
    Aug 2013
    36
    Thanks for the welcome
    Aug 2013
    36
    I have had a search on the forum, Can not seem to find any good information about induction on the a3,
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    819
    Add Vex182 on Facebook
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, N249 bypass, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Dec 2012
    Ireland
    29
    S2000 prob the cheapest and most beneficial , but you will need a reducer if your car has a ko3/ ko3's
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    4,899
    Visit 16Klappe's Instagram Channel
    <tuffty/> likes this.
    I quite often say I'm going to do things.
    Then never do them.
    Aug 2013
    36
    Yea in that case i have all ready put a cone filter on it and a cold air feed to it so i will keep it like that,
    Unless anyone has a better idear open of offters if some one has found something that works better.
    Aug 2013
    36
    The little tab/nipple thing that is on the bottom half of th orignal air box at the very end closest to the wing what is that?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,453
    just a mount that locates it on to the inside of the wing
    Aug 2013
    36
    Ok kewl thanks just wanted to make sure i wasent leaving any pipes,breathers or sensors unpluged after fitting a cone filter
    Jul 2013
    Uckfield
    72
    Follow fanta On Twitter
    What have you done with the cold air feed? I've noticed the car doesn't quite pull like it did now I've put this and the oversized tip on.
    Thinking about making a blanking plate out of metal, there's a good guide here on asn. But the cold air feed is what I think is lacking, before with the box it had direct connection to cold air, now it's got a mix of both...
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,453
    temp of the air pre turbo means naff all on charged cars.
    Larger tips tend to move the power curve to the right a bit, less lower down, more up top. With an up to date map taking into account the mod/s that wouldnt be the case.
    Should feel nice and free top end tho, 6k+
  1. helpppp!!!!! Jetex filters or Bmc cone, bmc induction
    By valyboi in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th January 2013, 18:33
  2. replacement cone filter(NOT jETEX)
    By Paradox1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th December 2012, 17:26
  3. Anyone with a cone filter fitted or made a heat shield??
    By technics100 in forum Diesel forum
    Last Post: 17th January 2006, 22:29
  4. cone filters
    By imported_kris_tdi in forum Diesel forum
    Last Post: 10th January 2006, 18:52
  5. Green Filters Single Cone Induction Kit
    By pazaz in forum Tuning
    Last Post: 21st October 2004, 21:23
