Chris NottBadger5
    Nov 2012
    London
    14
    2003 8l 1.6 Petrol Manual Gearbox Oil Filler Plug Removal Tool
    I need to change my gearbox oil.
    My Haynes manual shows the filler plug location. However, the fitting is much bigger than the drawing in the manual. It looks like it need a circa 35mm hex drain key / Allen key? Does anyone know where I can get one? I've tried amazon and eBay with no luck.
    And to make matters worse it looks like the clutch line is in the way too...
    BENJAMIN's Avatar
    Mar 2011
    472
    That's not the drain plug dude, do not attempt to remove that plug!The drain, and refil plugs are both 17mm hex plugs. Drain is at the back of the box, underneath. Refill is on the end of the box, in the wheel arch direction.
    '09 Lci 335d individual. M-dev stage 2, 360bhp 550ftlb. 'Undercover police edition'
    Nov 2012
    London
    14
    Quote Originally Posted by BENJAMIN View Post
    Haha amateur.
    Thanks a lot, what's behind that plug?
    BENJAMIN's Avatar
    Mar 2011
    472
    Quote Originally Posted by beagle2 View Post
    Haha amateur.
    I think it supports some of the linkage inside the box! Lol
  1. Manual gearbox oil
    By dex140 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th March 2012, 09:27
  2. Oil filter cap removal tool
    By Geraldy212 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th April 2011, 08:48
  3. gearbox oil drain plug special tool
    By adrian2006uk in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th July 2007, 14:24
  4. Replies: 0
    Last Post: 19th June 2007, 16:44
  5. Leaking gearbox oil 2.5TDI with a manual 6 speed gearbox.
    By Joni_s in forum A4/S4 forum(B5 Chassis)
