Sky InsuranceEM Tuning
Results 1 to 14 of 14
Like Tree3Likes
  • 1 Post By gasfitter
  • 1 Post By Vex182
  • 1 Post By bez101
Thread: Picked up my S3 this afternoon and....
    Aug 2013
    11
    Question Picked up my S3 this afternoon and....
    ..... I have say, very nice. Bit of a more solid ride than the VR6 but Ill get used to it
    noticed though that the temp sensor didnt move off of zero which was a little concerning.
    When I parked up the fan overrun went on for a short time but for all I know thats normal ; some boiler do that
    water temp sensor?
    Sandra likes this.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,446
    Glad you got the car. Any pics for us? x
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    878
    Add Vex182 on Facebook
    Welcome! Yeh temp sensor sounds about right or the thermostat stuck open possibly too, both pretty common.
    gasfitter likes this.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,475
    CTS easy to fit
    thegoal007's Avatar
    Another S3 owner....
    Apr 2008
    surrey
    729
    common issue and nothing really to worry about. Did you road test thoroughly and it's just happened ?
    02 plate - 2002 - 225bhp - S3 - Ming Blue - completely standard - nuff said, OK there's a centre armrest, sunroof, BOSE speakers & black leather recaros, oh and the non OE chrome pack !
    Aug 2013
    11
    To be honest, we went out on a 10 minute jaunt the day before. I was too busy listening for sounds to see right in front of me on the dashboard. Never had a turbo car you see
    Aug 2013
    11
    Quote Originally Posted by Vex182 View Post
    Vex, is the repair in the stickies/how too's?
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    If you look to the right of the engine block you should see a pipe with a sensor mounted into it (normally a green sensor). This is the CTS you can get a replacement from the dealers for not too much money. You just pull out the retaining clip (do it with a cold engine to minimise coolant loss) and then pull out the sensor. The new one should come with a new o ring so make sure you use that and then refit.
    Thermostat isn't the hardest job in the world but is a bit fiddly due to the location. If you do want to replace it if the CTS does not fix your problem then I would recommend getting a new thermostat from the dealers again as they are a bit more expensive but much more reliable. Guides to replace can be found using the search function or via google.
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    Aug 2013
    11
    Quote Originally Posted by vrbob View Post
    Bob, much appreciated mate, thankyou
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,896
    VR6
    vivalacoulter's Avatar
    May 2013
    S. Wales
    194
    Follow vivalacoulter On Twitter Add vivalacoulter on Facebook Visit vivalacoulter's Instagram Channel
    Any pics of the new car?
    Aug 2013
    11
    Cool
    Quote Originally Posted by vivalacoulter View Post
    yea, will do this weekend
    Nov 2012
    Kent
    459
    Add Tim_Attard on Facebook
    temp sensor first as the thermo is a right pita, congrats on the car
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/187166-tims-max-power-a3.html
    Quote Originally Posted by 16Klappe View Post
    Don't listen to him Tim, You're my hero, I'm proud of you.
    Alex C's Avatar
    Lizard, Cornwall
    2,600
    whilst a stuck thermostat will usually make the engine run cold it certainly wouldn't be at 0°C.... change the CTS
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
  1. Collected my new rims this afternoon
    By Niknak in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st April 2007, 21:32
  2. WOOHOO! Picked up new S3 this morning!
    By a3norwich in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st March 2007, 17:28
  3. Collecting my car this afternoon!
    By mandyray in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th October 2005, 12:29
  4. Had a spin on the back of a R1 this afternoon!!
    By Soupie69uk in forum General Chat
    Last Post: 14th June 2005, 14:18
  5. Picked up S4 - is this normal?
    By imported_SunDiver in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th February 2005, 00:11
