Chris NottAH Fabrications
Results 1 to 23 of 23
Like Tree6Likes
  • 1 Post By [Dave B]
  • 1 Post By 16Klappe
  • 1 Post By kwistof
  • 1 Post By superkarl
  • 1 Post By Dani_B19
  • 1 Post By Neilybabs
Thread: Car flooding after mods
    Banned
    Mar 2006
    Maidenhead
    657
    Hello peeps,
    I have a '98 A3 1.8T (AGU) that had a Jabbasport re-map a few years ago. All gravy.
    At the end of last week I picked the car up after having a Forge FMIC, Forge TIP and Toyosports 3" downpipe fitted. I also fit the S2000 cone filter mod and was left with what looked like an air flow sensor? So I zip tied it as close to the filter as I could. Happy days.
    I got about 10 miles and stopped at a junction and the car cut out. It seemed like it was flooded as it wasn't having any of it and stank of fuel. I went back to it a few hours later and it started first time and managed to get it home.
    I've bought a new K03s which I was going to sling on it before a re-map. Do you think the above is because I haven't had it re-mapped after the mods?
    Any advice is gratefully received as ever.
    Neil
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    Have you refitted the MAF (Mass Airflow Sensor) between the TIP and the filter? If not then you've left the engine without any idea of what air is coming into the system.
    Pics speak a thousand words, but this sounds like your problem.
    Neilybabs likes this.
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    Banned
    Mar 2006
    Maidenhead
    657
    Thanks for your reply.
    I'm unable to get a pic at the moment but will try to as soon as I can.
    The MAF is definitely on the car. I'm wondering if some oil from the new filter or silicone grease has made it's way in there?
    www.badger5.co.uk
    May 2004
    nr Glos
    6,944
    s2000 filter are dry
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,115
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Mine was very lightly oiled and certainly not 100% dry when it was delivered from car parts 4 less.
    Think it's done to withstand moisture?
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    4,904
    Visit 16Klappe's Instagram Channel
    As Bill says. S2000 filters are dry, they are a paper element.
    Fitting the mods will not have caused your issues. Fitting them badly will have.
    Plug into vcds and check for codes.
    I quite often say I'm going to do things.
    Then never do them.
    kwistof's Avatar
    Jun 2010
    SE Kent
    2,115
    Quote Originally Posted by 16Klappe View Post
    The paper part of the filter was dry....but there was still quite a bit of oily residue in the packaging and around the plastic parts of the product.
    Far more than I was ever expecting...so went back and read through the S2000 thread and several other people have mentioned they found the same.
    Btw, OP I realise the MAF is on the car.... but make sure the MAFs electrical connector is properly plugged in and secure- should hear a 'click' to know it's securely in there.
    Next step would be to check for codes with VCDS as Jardo advised above.
    2000 S3 APY
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,455
    make sure the maf is installed the right way round
    Banned
    Mar 2006
    Maidenhead
    657
    Thanks all for the advice.
    I don't have access to VCDS unfortunately, so can't give you any codes etc.
    I've had a word with the garage and I'll see if I can get it back to him, although i'm a bit wary of driving it as it cut out a second time when joining a roundabout. Great fun.
    Is it worth taking the MAF off and cleaning it?
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    Are you sure it's installed the right way round and the plug is fully clicked in place?
    > S3 225 (03) - OEM+
    View: My S3 diary
    Banned
    Mar 2006
    Maidenhead
    657
    I've just pushed the connector in and didn't hear a click. I took it off and pushed it back on again to be sure.
    I noticed a small black arrow pointing towards the TIP when I removed the connector. Is this the right way round?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,455
    yes thats the right way
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    Did it drive fine before you fitted the filter? Just thinking that it could be downpipe/lambda related. Obviously fault codes would help.
    > S3 225 (03) - OEM+
    View: My S3 diary
    Banned
    Mar 2006
    Maidenhead
    657
    It did drive ok when I picked it up but I didn't really go any great distance.
    I've put the standard air box back on and it's stalled twice since. Wish I had the apparatus to supply the codes!
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,173
    Doesnt the agu have N ignition module that connects onto or into the airbox? Has this been disturbed or not fitted right?
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,904
    Yep.
    Then never do them.
    Banned
    Mar 2006
    Maidenhead
    657
    This must have been the bit that I took off when I installed the S2K filter then....
    I just had a quick look at this and the seal isn't complete where I've tried to push it back in. Booger. Could this be the route of all evil?
    What would I do with the ignition module if I wanted to stick with the cone filter?
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,904
    Just leave it plugged in and tuck it out the way, try ziptieing it to the bulkhead.
    Then never do them.
    Banned
    Mar 2006
    Maidenhead
    657
    So I guess the fact that it isn't seated correctly now isn't the main cause of the problems.
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,904
    Not going to help, but won't cause it to run as you have described.
    Then never do them.
    Banned
    Mar 2006
    Maidenhead
    657
    Righto. Thanking you Mr Jardo.
    Banned
    Mar 2006
    Maidenhead
    657
    Quick update. With the MAF disconnected it starts and runs. New MAF required. Coincidence I guess?!
    Once again, thanks all for the advice. Gotta love ASN. Love you long time.
    Banned
    Mar 2006
    Maidenhead
    657
    For info, if anyone is looking for a genuine Bosch MAF (Part No. 0280 217 117), try: www.germanautosupply.com. A US based company.
    The final price was about 110 notes (shipping included) compared to about 135 on a popular online auction site.
    JudderMan likes this.
  1. Car feels better then ever after mods today!
    By Customboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th April 2012, 19:51
  2. Advice on car repair after accident
    By KARL in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th July 2008, 14:30
  3. What next after modded TDI?
    By drewwa in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th December 2007, 20:41
  4. Car back after 2 weeks
    By doeboy in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th February 2007, 23:55
  5. CHIP POLL/CAR PROBLEMS AFTER CHIPPING - CAST YOUR VOTE?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd March 2005, 21:06
