    May 2013
    Scotland
    P1296 Cooling System Malfunction
    Ive got this code through on my 2001 1.8t 8l, just the sport, and ive done a little research myself, and it seems to come up with the same 2 issues, thermostat, and temp sensor? and idea how to narrow it down? Cheers!!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,450
    17704/P1296/004758 - Ross-Tech Wiki
    17704/P1296/004758 - Error in Mapped Cooling System
    Possible Symptoms
    Cold start issues
    Possible Causes
    Coolant Temperature Sensor (G62) faulty
    Coolant Thermostat faulty
    Possible Solutions
    Check Coolant Temperature Sensor (G62)
    Check Coolant Thermostat
    Special Notes
    Check the stored Freeze Frame data with this fault code. Freeze Frame information will be found in the fault code description (if the module supports it) or in Generic OBD-II if the vehicle complies with those regulations.
    Freeze Frame data stored at -40 °C is generally an indication of a faulty ECT or wiring.
    Freeze Frame data stored at +140 °C is generally an indication of a faulty ECT or wiring.
    Freeze Frame data stored with in the 60-80 °C range is an indication that the vehicle was close to, but not within, the cooling systems normal operation range. The Thermostat itself or Cooling system components may be at fault.
    What temp is indicated on the dash?... normally its a faulty CTS but if the temp doesn't get to 90 at all it could be the stat... stats are around a tenner, CTS 15-20 quid from a dealer (pattern parts are prone to failure)
    <tuffty/>
  1. cooling system malfunction
    By knoxie in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th December 2011, 08:49
  2. 17704 P1296 Error in Mapped Cooling System
    By S3AMK in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd February 2011, 23:54
  3. Cooling system
    By Bula_82 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd October 2006, 11:55
  4. Absolute with Badger and Cooling System
    By myrichdad in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2006, 17:51
  5. Cooling system ?
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd January 2006, 22:14
