Volks AutosAH Fabrications
Results 1 to 8 of 8
    Nyteryda
    Surrey
    222
    S3 Throttle Body Pipe Internal Diameter ..
    can anyone give me the i/d of the s3 throttle body pipe ? piecing together an r32 conversion and need to get a pipe reducer, thanks
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    You want the O/D don't you?
    There isn't much about that reduces an R32 tb to 60/63mm pipework...
    What are you trying to do and re-use exactly? I used an SFS 83 - 70mm straight reducer but I also made custom pipe work up... std 60mm TB is (shockingly) 60(ish)mm ID and 65ish OD... R32 TB is 75mm ID and just over 80mm OD... you will also need to weld a bead on the end of the R32 TB as it will pop off under boost
    <tuffty/>
    Nyteryda
    Surrey
    222
    <tuffty/>
    i've got a silicone hose going from throttle body to ic and the internal diameter seems to be roughly consistent with the o/d of the throttle body
    i bought an r32 throttle body, 83mm 90deg bend and have found an alloy 83-63mm reducer ..
    needed to know what the i/d of my silicone ic to tb pipe was and 65mm looks to be the approx answer so i guess the 63mm reducer should be ok
    Nyteryda
    Surrey
    222
    using the ol' hairspray trick of course !
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    You could always measure it... using a ruler...
    Slightly better than guessing...
    <tuffty/>
    Nyteryda
    Surrey
    222
    yes but the car isn't with me at the mo and wanted to get the bits sorted tonight .. have gone for the 83-63mm adapter for now which i hope will do the job, cheers
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    What intercooler is it?...
    <tuffty/>
    Nyteryda
    Surrey
    222
    <tuffty/>
    the guy who had the car before me said it was from a nissan skyline, whether it is or not i have no idea
  1. 1.8T throttle body diameter
    By Alan H in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th March 2013, 20:46
  2. cleaning throttle body
    By Danielson in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th September 2004, 18:57
  3. Throttle Body
    By imported_Cali in forum General Technical / How To
    Last Post: 22nd July 2004, 22:40
  4. Throttle Body
    By darrenp in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th May 2004, 12:33
