AH FabricationsChris Nott
Results 1 to 7 of 7
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    373
    Quick Bolt size question
    Hi guys I am replacing my front seats and there is 2 ... What look like torx bolts on the front of the seat. Anybody know what size these are? Look quite big. Thanks
    Mar 2013
    Devon
    394
    You mean the 2 to remove the seat? These are 'usually' just 13mm nuts.
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    373
    Yes buddy. They normally are but not mine its an a3 1998 1.8t
    Mar 2013
    Devon
    394
    Seem to recall the non 13mm nut ones are T40 torx. Not 100% on that tho.
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    373
    Quote Originally Posted by JimS3 View Post
    OK thats great thanks. Would like someone to confirm as your not 100% then I'll get purchasing!
    Mar 2013
    Devon
    394
    Why not pick up a set? Buying individual bits is normally an expensive way of buying. T15, T20, T25 & T40 are used a lot on VAG stuff, expecially interior. Useful to have.
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    373
    Good idea, although I do have a set but doesn't go big enough for those two under-seat bolts. Purchased a T40 anyway as only 99p delivered and will probably only use it this once! Thanks for you help buddy, cant wait to get rid of these old worn tatty seats.
  1. Quick tyre size question for RS4 B5 alloys.
    By Dan Gliballs in forum General Chat
    Last Post: 6th November 2006, 07:34
  2. Quick Tyre pressure question
    By imported_Wicked666 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2005, 08:11
  3. 17" alloys tyre size question
    By rasA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th February 2005, 22:27
  4. Tyre Size Question on RS4/TT Original Alloys
    By imported_spuddie007 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th February 2005, 00:29
  5. Bolt size for the hub on a 1999 A4 Quattro Turbo
    By swsimon in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th June 2004, 18:56
