Badger5Chris Nott
Results 1 to 10 of 10
    Jun 2012
    119
    Please has anyone got a diagram of a fuse box for a 2001 A3?
    Hi all,
    My A3's air con has stopped working and I have had it checked for gas level (it was fine) and also checked for leaks and it was fine. However, every morning the dashboard lights flicker all the way to work and my central locking has stopped working, which perhaps isn't too bad a thing as the alarm kept going off lately for no reason.
    My electric windows ALL stopped working and I managed to locate the faulty fuse and change it and now they are fine but I wonder if the air con problem could be a fuse? The blower still works just fine though.
    Please could anyone supply me with a diagram of which fuse is which please?
    Thank you in advance,
    B
    epox's Avatar
    Oct 2012
    Glasgow
    593
    is there not a diagram on the back of the cover u take off to get to the fuses?
    fuse numbers are above the fuses, quite hard to see iirc though
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Check the fuses on top of the battery.. the 'fans' fuse commonly corrodes and if no power here then aircon doesn't work... 3 x 30amp fuses, one in question is the one on the left looking in the engine bay
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    ..should also point out its worth doing a full scan with VCDS of all modules to see if there are any fault codes for some of these issues... most of the electrics are controlled by modules and most modules record fault codes
    <tuffty/>
    Jun 2012
    119
    <tuffty/>
    Thanks for that Tuffty, I checked the fuses and unfortunately they were fine (They look solid buggers too).
    Please can I ask what a VCDS is?
    Also, does the fact that the dashboard (Revs, speedo, fuel gauge etc) lights are flickering make any difference to what the problem may be?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Definitely need to scan for fault codes... the problem with your dash could be the speed sensor in the gearbox but as your lights are flickering it sounds like a power issue and that could be down to the earths under the battery tray or the power distribution on top of the battery...
    Read this for info on VCDS
    IMPORTANT! - When posting asking for help... - PLEASE READ BEFORE POSTING (UPDATED)
    <tuffty/>
    Jun 2012
    119
    Hi again,
    OK, I have scanned for codes and found the following:
    18057 -163 03/04
    KWP 1281
    Powertrain data bus:
    Missing message from abs controller
    P1649
    1062 -163 01/04
    KWP 1281
    Please check DTC
    memory of instrument
    Cluster: P1654
    17978 -35 04/04
    KWP 1281
    Engine start blocked
    By Immobilizer
    P1570
    Static -no
    Does this help at all please?
    Jun 2012
    119
    Hi there,
    Please can anyone give any thoughts on these?
    Oct 2013
    41
    Did you manage to come to some conclusion regarding the instrument cluster?
    puggsy21's Avatar
    Oct 2013
    Kent
    82
    This isnt the best picture in the world but you can zoom in to see it better sorry only had me phone to use direct from my owners manual hope it helps you out
    Fuse number 25 - Heater blower, Air conditioner 25 amps (left hand side of the 3 rows, 2nd down)
  1. HAS ANYONE GOT PICTURES OF A4 B6 SITTING ON EIBACH SPORT-LINE,PLEASE !
    By Digger1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th March 2010, 20:59
  2. Has anyone got a chipped S3 (265 BHP MOD)
    By daztenerife in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2005, 08:24
  3. has anyone got....
    By Kipper in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st December 2003, 12:00
  4. HAS ANYONE GOT A PIC OF THE A4
    By RobG in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd July 2003, 12:46
  5. Coil Packs - has anyone got one!
    By audi_girl in forum General Chat
    Last Post: 10th January 2003, 21:11
Tags for this Thread
