Sky InsuranceChris Nott
    Aug 2013
    Cambridgeshire
    2001 A3 1.6 Sport.
    2001 A3 1.6 Sport.
    Hi guys and girls, im after some help with my A3. It seems like a lot of Audi's lights on the dash is a common thing, so i will leave that for now. My problem is, i seem to be burning alot of oil, and using a lot of coolant, even when im driving like a little *****. I can't see any obvious leaks, but when i stop i can hear a water pressure sort of burbling round the back of the engine...any takers?
    Also any error codes ive got dont relate to this issue.
    mark_S3's Avatar
    Yorkshire & Humber Events Rep
    Sep 2012
    Wakefield
    600
    Headgasket? Gone
    Sounds like it if it's using both water and coolant.
    Check both the coolant tank cap and oil cap for signs of mayo like gunk.
    And get a compression test done.
    ***2000 Audi S3 8L APY***
    * Milltek CATback * Milltek 200 Supercell Sports CAT * SuperChips SPS Stage 1 Remap * Forge 008p *
    * 18" Audi TT 240 Sports Alloys in Gunmetal Grey * Pagid Discs with BD Predator Pads *
    * Badger5 v2.2 TIP, JR Filter with Heatshield * N249 Delete * N112 Bypass *
    * PowerFlex ARB Bushes * TFSI Coilpacks * Saikuo Michi S3-OCC *
    * PowerFlex Rear Engine Mount Bushes *
    [IMG][/IMG]
    Jun 2008
    22
    Coolant leak could be from the plastic connection block on the right side of engine. Look for pink residue left by leaking coolant.
    as for oil leak, put some cardboard under engine and you can see where any leak is coming from.
    if you can't see any signs of oil or coolant loss then it may be head gasket problems.
    Aug 2013
    Cambridgeshire
    Thanks for the response, ive spent the day looking for signs, its doesnt seem like head gasket, no "gunk" or any unusual smoking.
    I did however see that my dip stick case is broken, so doesnt give an air tight seal. also i know i need a new oxygen sensor. could be a collection of things making the ecu using more.....
  1. help on 2001 A3 1.8t sport standard wheel and hub spec?
    By gavcav in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th November 2010, 16:22
  2. Loose Heat Shield oon Cat - 2001 A3 1.8T Sport
    By A3Monster in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th September 2009, 20:21
  3. 2001 51 A4 TDI SPORT MISSING WHEN IT RAINS
    By nafmughal in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st July 2009, 18:35
  4. Recommended battery for a 2001 1.8 T Sport
    By Antony 171008 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th December 2008, 09:55
  5. 2001 1.8T Quattro Sport Rear Shocks
    By mtaylor55 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd March 2007, 21:05
