Volks AutosChris Nott
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    Aftermarket clock faces. Fitting...
    As subject has anyone ever fitted some aftermarket clock faces? Or does anyone know what sort of job they would be to fit?
    Cheers Mark.
    Aug 2005
    essex
    33
    Re: Aftermarket clock faces. Fitting...
    do you mean like the lockwood dials sort of thing, as my a3 came standard with white dials
    imported_Cali
    Never done it on an Audi - used to do it on MKII Golfs a lot - bit findley you have to watch the platic clips the break easily.
    Good Luck
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    Yeah lockwood style ones.
    So how do you go about fitting them in general? How do you fit them over the needles? Do you have to remove them?
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Personally I thing fitting these faces will cheapen the look of your dash board. I thin kyour dials look fine as they are, but each to there own.
    If you have to fit them, it depends on whether they are a stick on or replacement faces.
    If you have to remove the needles the best way is to place a couple of credit cards (or normal card) either side of the needle and then lever the underside with a couple of dinner knives.
    Jul 2005
    2,488
    got to agree that replacement dial faces are horrible. They'll almost certainly not look like an OEM finish, and you'll forever risk your needles dropping off.
