Badger5AH Fabrications
Like Tree1Likes
  • 1 Post By superkarl
Thread: Car not sitting level
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Hi all, not posted a thread for a while but got a niggling issue and wondered if anyone has had this problem before
    I've got AP coilovers with the adjusters removed at the back and for a while now the car seems to be quite a bit lower on the drivers side rear, about 10-15mm. I've had a quick look underneath but everything seems to look fine, tie arms are solid, spring isn't broking, damper isn't leaking.
    I've also changed the rear springs to jamex thinking that it could be faulty AP springs but that made no difference so i've put the AP springs back on.
    Worns bushes? If so which bushes, i'm lost
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    front trailing arm bushes perhaps.
    When was alignment last done? It could be out slightly, if one side doesnt mirror the other it might appear different, like if the tie bars are different lengths.
    bush number 4 (well worth changing)
    Powerflex - Performance Polyurethane Bushes
    Sandip likes this.
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Alignment was done about 18mths ago, he struggled to get it perfect though, maybe because of worn bushes
    Think i'll have to get the front trailing arm bushes checked out, it seems like it's getting lower over time, wish the passenger side was the same tbh because i like how low the driverside is :D
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    rebush the whole rear end, its worth doing anyway and might solve it.
  1. Picked up the car! Not all well tho!
    By S3 Wannabe in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th December 2008, 08:18
  2. S3 not sitting level.
    By S POT in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st December 2007, 16:48
  3. New car, not!
    By nicks3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd September 2005, 13:26
  4. Truck V car (not pretty)
    By fallmonk in forum General Chat
    Last Post: 26th June 2005, 11:47
  5. Def. Problem, Car not starting when cold!
    By charTT in forum TT/TT-S/TT-RS Forum
    Last Post: 14th April 2004, 22:10
