Sky InsuranceAH Fabrications
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By <tuffty/>
Thread: Valve guide replacemnt - Help please
    Scullies's Avatar
    Feb 2012
    Dubai
    1,241
    I have taken my mates TT head to get the valve guides replaced. Now the machine shop says they need to grind the valves and seats as the valve angle will not be the same with the new guides.
    I may be wrong but this doesnt make sense to me. Surely if you remove the existing guide and press the new one in, the valves are going to be in the same position.
    Are they correct or are they spinning me a story to make an extra buck?
    Jan 2011
    northants
    165
    they are correct
    the valves will sit at a slightly different alignment so you will need to reseat them to get a correct seal
    if hes doing this then get them to redo the valve seats in the head
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,019
    Visit 16Klappe's Instagram Channel
    Imagine the valves have been sliding up and down the inside of the guides; they will gradually wear themselves a small groove which they often run through. This slightly changes the angle the valves run through the guides at over time. Because it is gradual everything wears together.
    Replace the guides with brand new perfectly straight guides and this wear has been taken away, meaning that the angle the valves travel has changed slightly due to the lack of wear. But the valve seats remain untouched.
    Very simple when you think about it.
    I quite often say I'm going to do things.
    Then never do them.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,467
    After a guide replacement they need to be at least to be re-ground... seats may need re-cutting if wear on guides was excessive enough that there is pitting on the seats/valves or they have worn that badly that the valve mad a new profile..
    Re-grinding valves is a given if its apart tbh...
    <tuffty/>
    RIP S3dave
    May 2004
    nr Glos
    7,141
    never yet had to recut seats byond just normal lapping in..
    jardo.. the wearing bit is the inside of the guide not the outside of the guide to head, so if pressed in they should still align with valves seats, but their tooling for reaming to size will determin the actual angle.... which if they set them up aligned to begin with they should align afterwards.. Its not uncommon for seats to need a slight tickle.. My local m/c shop checks the valves for seating with engineers blue to confirm they will need normal lapping. They do say if they wont lap in bring it back and he will recut the seat slightly to suit the new guide. Not had to do this bit as yet
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    I plan on only lapping them back in.
    Scullies's Avatar
    Feb 2012
    Dubai
    1,241
    <tuffty/>
    When you say re-ground, do you mean lapping them in with grinding paste?
    t
    That was my plan.
    The valves and seats are in good condition. All valves have a nice consistent ring where they have been sitting on the valve seats. No pitting on the valves or seats.
    Guess I will try another machine shop and see what they think.
    Thanks for all your input guys
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,467
    Quote Originally Posted by Scullies View Post
    Yes
    <tuffty/>
    Scullies likes this.
  1. mfsw guide? help please
    By james1985 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th February 2013, 01:16
  2. a4 b5-6? buyers guide help please
    By Jon Blackman in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th October 2012, 08:55
  3. Window Guide help please
    By LaSarthe&Back in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th June 2008, 13:44
  4. help please!!!! audi 5000 problems needing hep
    By grantk in forum Classic Audi Forum
    Last Post: 5th May 2004, 01:32
  5. I.T. help please!
    By MisterD in forum General Chat
    Last Post: 20th January 2003, 21:19
