Volks AutosChris Nott
Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By 16Klappe
Thread: turbo or dv
    jimmer 22's Avatar
    Dec 2010
    cornwall
    66
    Add jimmer 22 on Facebook
    turbo or dv
    I have just repaired a couple quite bad leaks on the pcv system. Bad enough that I couldn't even get over 5 psi in the system with my leak tester. Its still not perfect but its a hundred times better. I will be getin rid of the hole system as soon as i can so it will do for now. Iv took it out for a run and the turbo sounds alot louder, at least I think its the turbo. Would this be normal? Only other thing I can think of is that the crappy standard recirc valve isnt workin properly. Boost seems slightly spikey aswell. Any input greatly appreciated. Cheers
    chaz20vt's Avatar
    Aug 2012
    419
    Have you had it on vcds mate?
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    4,899
    Visit 16Klappe's Instagram Channel
    Quote Originally Posted by jimmer 22 View Post
    The "crappy" standard 710N is better than almost all "aftermarket" valves.
    Put a new 710N on and see what happens. £31inc VAT at TPS.
    I quite often say I'm going to do things.
    Then never do them.
    Aug 2013
    26
    Take the original dv off mate and check around the nipple on the top as they tend to crack around the nipple and the edges next to the nipple, had the same prob with mine so ive put another on and now i have good boost :-)
    jimmer 22's Avatar
    Dec 2010
    cornwall
    66
    cheers guys. have replaced it with a forge 007p and is alot better
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,899
    For **** sake.
    Then never do them.
    jimmer 22's Avatar
    Dec 2010
    cornwall
    66
    Lol whats up 16klappe. Thought these were the best valves to put on these....
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,899
    Quote Originally Posted by 16Klappe View Post
    As per this ^ and 99.9% of people who know what they are talking abouts recommendations.
    007p valves look great and can work just as well as a standard valve, but often don't seal correctly and require maintenance and regular pressure testing.
    Make sure you have the revised piston with rubber o-ring, otherwise you are just putting off the inevitable and will end up for a scored piston and worn sealing surface which will mean lapping in and resealing.
    A DV only does one job, relieve pressure from the pressurised intake tract. A stock DV does an excellent job of sealing and relieving pressure quickly.
    A stronger sprung 007p will in theory only release pressure slower. And as the pressure on the top of a 007p (and stock DV) is pressurising the seal as well as providing the suction to open the valve the weaker the return spring you can get away with the better.
    A stock DV is PERFECT for our cars on their standard turbo up to as much air (and beyond) as our stock turbos can flow an compress.
    Did you buy new or second hand?
    Then never do them.
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,899
    Have a read of this thread.
    Where I was utterly schooled and made to look an idiot. But learnt a lot when I thought I knew everything.
    Interesting Dump Valve Information For New Buyers And Owners. Servicing Etc
    Then never do them.
    jimmer 22's Avatar
    Dec 2010
    cornwall
    66
    Ah, ok. Well now I know. Lol. I bought a new one. I read a couple of threads on here saying that the 007p works great with a badger5 intake kit, which is next on my order list so I went with that.
    Cheers for your input tho.
    I know for next time
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,899
    If you bought new it should have the rubberised o-ring, so should work just as well as standard but look more bling.
    B5 TIP is a must have for a K04
    Sorry if I seem grumpy, I am generally.
    azman likes this.
    Then never do them.
    jimmer 22's Avatar
    Dec 2010
    cornwall
    66
    Haha. No worries mate. Yeah like I said its first on the list. And its a long list, lol.
    Jul 2013
    Uckfield
    72
    Follow fanta On Twitter
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,453
    The good thing is forge have now realised the flaw in their design after people leak/seal testing them. So if people are buying new then theyre ok, people buying old style ones second hand are the suckers.
    Diaphram valves over piston anyday.
  1. Logging turbo boost with VAG-COM
    By Ram in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th January 2009, 22:23
  2. Turbo noise
    By AndybS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th July 2003, 21:10
  3. turbo hose set
    By waynehiscock in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th May 2003, 23:24
  4. Hot Turbo Pic
    By mramage in forum Other Brands & Models
    Last Post: 23rd March 2003, 23:36
  5. CLIFFORD Car alarm (Turbo Timer thing)
    By A4Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2003, 13:03
