Badger5EM Tuning
    Aug 2013
    8l 1.8t problem shooting help
    Hi just bought a 8l a3 1.8t sport and have a few problems...
    1stly engine management light came on and lost the speedo?
    Secondly oil sensor has come up, put oil in but still there?
    Another the battery went flat, since then, the radio doesn't go off with ignition, the windows don't go up automatically (have to hold switch)
    Lastly (for now) when I put side/dip beam lights on, the front fogs and the reverse lights come on? Could this be an earth or any other help?
    If people could help with any of these would be Awsome thanks
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,640
    Seems you have some wiring issues with the lights.. Check your wiring on your rear and front lights.
    Use VCDS to scan for your faults! Alot of them will be picked up.
    Aug 2013
    What's vcds? Same as vagcom? Anyone else had these problems??
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    To fix the windows thing you need to just hold both switches up for 5 seconds (ignition on) and it re-enables one touch...
    The fog lights issue maybe because you have pulled the light switch out to turn on the fogs... these come on with the sidelights... I would read the manual if you have one to fully understand how the switch works as it can be a little confusing initially but intuitive once you have the hang of it..
    Reversing lights thing is most likely a poor earth or an issue with the rear light clusters... you don't have aftermarket lights fitted?
    As suggested scan with VCDS (formally VagCom)... there is information on how to get this sorted in the FAQ thread in the stickies or the link below my build thread link in my signature below
    <tuffty/>
    Aug 2013
    Thanks for that.. I am meaning to check earths once I get 2 mins, fog light nope I'm not pulling the switch out lol I'm thinking it could be a faulty switch? Or earth?
  1. RSN Headunit Problem Mp3 - Help!!
    By Leetaylor in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th July 2006, 09:58
  2. Cabriolet Roof Problem - Please Help!
    By StuartC in forum Classic Audi Forum
    Last Post: 8th July 2006, 20:22
  3. Brake Problems - Please help
    By technics100 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th April 2006, 23:00
  4. BIG PROBLEM,NEED HELP FELLAS
    By imported_RELOADED99 in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th January 2005, 19:18
  5. S3 Instrument Cluster Problem - PLEASE HELP !
    By imported_G123 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th November 2004, 08:03
