Volks AutosSky Insurance
Results 1 to 11 of 11
    Aug 2013
    6
    Audi A3 1.6 Temp Gauge no higher than 70...Please Help
    Hi all,
    I have just got a 1.6 Petrol 2001 Audi A3 and it is fine apart from the temp gauge never goes over 70 when driving...but if you leave it idle it will go up to 90 but soon as you start driving it goes back down.
    Heaters do blow hot air so I am unsure if its the thermostat or the Coolant Temp Sensor. Can anyone help?
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,082
    Visit 16Klappe's Instagram Channel
    Thermostats gone.
    Good luck, do a search and there are how too's.
    /thread.
    I quite often say I'm going to do things.
    Then never do them.
    Jun 2008
    22
    If it is the thermostat, i can tell you it will cost about £40 - £50 as the thermostat on the 1.6 is map controlled and has an electrical connection. It is, however, very easy to change. Much easier than on the 1.8 engine.
    Aug 2013
    6
    Really...they are listed on ebay for about 10 pound for the thermostat :/
    AUDI A3 I (8L) 96-03 1.6 1.8 THERMOSTAT OE QUALITY | eBay
    Aug 2013
    6
    Also this shows a non computer thermostat :/
    Guide - Fitting thermostat 1.6
    Aug 2013
    6
    Jun 2008
    22
    Quote Originally Posted by tom163 View Post
    We should determine which type of engine you have before suggesting parts.
    A 2001 a3 1.6, I'm guessing it will be code AVU.
    Tom163: what is your engine code? It can be found on the first page of the handbook. I think it's the first three letters of the large code block.
    Aug 2013
    6
    Hi guys the code is avu
    Thanks for the help.
    Jun 2008
    22
    the AVU engine uses a map controlled thermostat. Part number 06a121114
    Aug 2013
    6
    Quote Originally Posted by kevin0410 View Post
    Thankyou for the help guys...would if be worth replacing the temp sensor also?
    Can anyone tell me were its located?
    Jun 2008
    22
    I wouldn't bother about temp sender, but if you want to you may as well do it when the coolant is drained down.
    as for the thermostat, remove the engine cover and you will see it at right hand side of the engine at the top. Remove two torx bolts, unclip the wiring and out it comes.
  1. Audi A4 1.9 tdi 130 S ECON light and temp gauge problem
    By dean2013 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd March 2013, 21:37
  2. Replies: 0
    Last Post: 23rd February 2013, 14:31
  3. Audi A3 FSI 1.6 Petrol (Too Slow to Move), Please help!
    By farzad in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th August 2012, 08:09
  4. Audi A3 dash temp gauge fault
    By r3ahj in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th January 2011, 23:23
  5. A3 temp gauge
    By adjturbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2003, 19:45
