Results 1 to 7 of 7
Like Tree5Likes
  • 1 Post By RGL
  • 1 Post By Lavis89
  • 1 Post By mattyboy199
  • 1 Post By losing it.
  • 1 Post By Lavis89
Thread: few little issuse
    Jul 2013
    north wales
    13
    few little issuse
    Hi, picked up my 2002 plate S3 on Saturday and all in all its a minter but it has the usual bubbling starting on the rails and EML is on but is coming up with 02 sensor bank 1 so that has been ordered.
    Some times it will take a while to start but no indication that the battery or starter motor is on there way out,any other possibilities?
    cheers hopey88
    RGL
    RGL's Avatar
    Free breather
    May 2013
    Way up north
    27
    Might be shooting completely in the dark because I'm not familiar with S3's specifics. But had a similar problem with my A3 taking a while to start. The problem was with the fuel pump. It didn't keep the pressure up while the engine wasn't running so all the fuel flowed back into the tank. Once you started the car it took a while for the pump to get the fuel up, which explains the long periods of hitting the ignition. Often when it took a long time for the engine to start, when it finally started (pretty roughly) the engine would cut itself out immediately. Heard that it was because of the ECU "thinking" that the engine is being over flooded with fuel by starting so long.
    The easiest way to test it (not 100% reliable, you wont know for sure till you've measured the pressures in the fuel line) is to hit the ignition only for couple of seconds. Don't do the long startings, just hit the ignition for couple of seconds. And then try it again right after. If your problem is like mine was, it will start right away on the second go.
    The problem could lie in a number of other things which could all be cheaper to fix. Blaming the fuel pump should be on the bottom of the list. Meaning try other things first before changing the pump.
    Sorry if I'm totally wrong guys. I'm still green.
    hopey88 likes this.
    Aug 2011
    Plymouth
    604
    Add Lavis89 on Facebook
    Crank sensor could cause the starting issues
    hopey88 likes this.
    2001 1.8T Quattro Sport 89k covered ARY engine.
    Remapped at Badger 5, 213bhp - 235lb/ft torque.
    HS2K cone, FMDV008, Silicon TIP, 18" RS4 (reps), AP coilovers, Catch can, n249 bypass, Toyosport 3" Downpipe/Decat, S3 Front brakes, Polyflexed Dogbone, S3dave adjustable tie bars
    Soon to be done: SAI delete, Install the toyosport FMIC i have kicking about in my living room
    mattyboy199's Avatar
    Nov 2005
    UK
    1,677
    just for the record my post cat o2 lambda sensor was playing up, i soaked it in vinegar for about a week reinstalled it & it hasnt thrown up a fault since (this was about 3-4months ago).
    hopey88 likes this.
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    Mar 2013
    europe
    76
    my car wont start til second go spluttering into life(it don't do it once warm) , its always started first time, found yesterday that the pcv pipe from the block upto that accumulator puck?, has completely severed itself looks like someone had used plumbing fittings inside of the pipe it was still attached one end but not the other, now it starts as soon as turn the key.,but i just keep getting more and more vacuum leaks fix 1, 2 more appear lol.
    hopey88 likes this.
    Jul 2013
    north wales
    13
    Cheers for the advice i'll get on it asap
    Anyone know about the warranty on the rails?
    Aug 2011
    Plymouth
    604
    depends on the dealer you go to, i had the dealer pay 70% of the costs to repair it, i still had to pay out over £300 though
    hopey88 likes this.
  1. Thinking about WMI... Just a few little questions
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th July 2011, 12:17
  2. help with a few little niggles please
    By clough103 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th September 2010, 09:05
  3. Few little jobs suggestions please
    By ex_scoobydoo in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th December 2009, 09:52
  4. A few little niggles
    By just017 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th May 2009, 20:36
  5. A few little bits..
    By phantom in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th January 2009, 12:25
Tags for this Thread
