EM TuningSky Insurance
Results 1 to 8 of 8
    Aug 2009
    Cheltenham
    335
    AEB Exhaust Port Size
    Has anyone got a AEB head on the bench that they can measure the true exhaust port size?? (Mine is fitted and I want to do some porting port on a 'Chinafold' before fitting)
    Dave
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    I think its 38mm.
    You dont want the manifold matched to the head, you need the head to be a tad smaller than the manifold to prevent/reduce exhaust gas reversion.
    Id take the manifold to gasket size if i were you. I know for a fact the gasket is bigger than the aeb exhaust ports.
    May 2010
    Bedford
    2,877
    36mm and 33mm for small port.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    Aug 2009
    Cheltenham
    335
    36mm or 38mm, I have got a gasket so I can certainly measure that size.
    Aug 2009
    Cheltenham
    335
    BTW Exhaust gasket is 41mm
    Mar 2013
    Devon
    613
    Quote Originally Posted by Jason.s View Post
    Yup, just measured my AEB head, the exhaust ports are 36mm.
    The AEB exhaust manifold measures 38.5 though, not that it's any use on a transverse car.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    If you leaving the head at 36 then its prob only worth having the mani 1 or 2 mm bigger.
    Aug 2009
    Cheltenham
    335
    Perfect guys, just the information I require, a slight step head to manifold then, thanks very much for you time.
  1. Exhaust tailpipe size??
    By Big Bird in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 22nd March 2010, 08:40
  2. aeb throttle body size
    By sam80quattro in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th March 2010, 17:18
  3. Exhaust bore size
    By james0808 in forum Tuning
    Last Post: 10th July 2007, 19:15
  4. A4 1.8T exhaust pipe size
    By billybravo in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th October 2006, 12:43
