EM TuningBadger5
Results 1 to 8 of 8
Thread: Oil grades
    Apr 2011
    Dublin, Ireland
    611
    Oil grades
    OK so the two grades of oil for an S3 according to Audi are 50301 & 50400, correct me if I am wrong. The only oils I could find in my local halfrauds were 50200 or 50500. Would these be suitable.
    B5 v1 Tip, B5 Exhaust Manifold, Beach Buggy Hybrid, Pipewerx D.P and cat bypass, Miltek resonated cat back, AH Fabs v2 Intercooler, S2000 Filter, 83mm 9.5:1 CP Pistons, Brute Rods, Bosch 550cc Injectors, Oil Catch can, N249 delete, B5 Phenolic Gasket, Devils Own Water Meth Kit, Forge baffled sump.
    H&R Springs, Koni FSD Shocks, s3dave's rear tie bars, R32 ARB's, LCR Brembo's, 18" ttrs alloys, replaced all suspension bushes, 15/20mm spacers front/rear, Vibratechnics Engine Mounts.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,459
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,254
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Leave Halfrauds be and get yourself to a TPS where you can pick up what tuffty has linked above over the counter.
    Trade Parts Specialists
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    Apr 2011
    Dublin, Ireland
    611
    Thanks Tuffty. So those numbers don't really matter all that much then. On a side note when it comes to the weight of the oil does that really matter also. Only asking as I still have a 5l drum of Silkolene Pro s 5w50 from my skyline days where that was the oil of choice or should I stick to 0-40/5-40/5-35.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,459
    Bin that off and put 5w40 platinum in... <end/>
    <tuffty/>
    Jun 2013
    Hampshire
    32
    He's in Ireland - do they have TPS there?
    if not then Quantum Platinum can be bought from any VW / Audi / Seat / Skoda dealer. Should be about £30 for 5 litres.
    However, Southampton Audi wanted to charge me nearly £50 for 5 litres!
    The 5W/50 is probably a bit heavy unless your oil temperatures are getting high - but a little used for topping up wouldn't hurt, rather than binning it!
    Apr 2011
    Dublin, Ireland
    611
    Yeah no TPS here. Anyway bought some mobil 1 0w40 fully synth.
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Quote Originally Posted by IrishDave View Post
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
  1. what transmission oil grade in my 2.4 v6 manual petrol
    By scanny1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th March 2012, 20:40
  2. Oil Min warnig - 2.0l TDI 170 Oil Grade/Spec?
    By S3 Dave in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th February 2012, 14:05
  3. Gearbox and rear diff oil grade's and quantity's.
    By Bradderz_1988 in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th March 2011, 23:56
  4. Oil grade for the ring
    By mattmackenzie in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th September 2010, 09:34
  5. 3.2 Oil Grade
    By edition in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th July 2010, 18:07
