AH FabricationsChris Nott
Results 1 to 19 of 19
    Midlands
    276
    What bushes to tighten things up
    Hi
    As above. My car is on 135k and the vast majority of the bushes are original.
    Which ones would you recommend to replace? Standard or are there better upgraded ones?
    Dave
    2001 S3 | 210/256/270 switchable APR software | Absolute Red |
    Squirrelofdoom's Avatar
    Feb 2012
    Surrey
    520
    Poly bushes are a fairly standard upgrade. Powerflex, Superflex...the list goes on
    Midlands
    276
    It's it a case of asking for a full kit at the garage,or specify specific ones?
    Dave
    cecilthesausage's Avatar
    ...It's Never Finished...
    Jul 2010
    Teesside
    933
    I got the full kit for mine including the dogbone..... Transformed the car.... Made it feel a lot tighter...
    Jul 2010
    Teesside
    933
    Midlands
    276
    Ouch!
    Obviously I can't fit them myself, how many hours labor would you expect so I can work out rough price?
    Dave
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Don't buy bush number 2 though... use TT solid bushes instead (8N0 407 181 B)
    <tuffty/>
    Jul 2010
    Teesside
    933
    I can't remember mate.... I got mine done a couple of years ago.... Just save the drawing miss out the ones Tuffty said and just chip away at them as funds allow....You will feel the difference with some more than others get them done first if money's tight..... I'm sure Paul will be back and tell you which to do first... I still haven't done my anti roll bar ones... They've been in my boot for about 2 years...lol
    Midlands
    276
    Paul, what order should I do them in?
    Dave
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Based on the pic in the link... position 1 & 2 first... also look at either LCR top mounts for the front struts or powerflex now supply them which are ironically cheaper than the LCR OE parts... for the rears just do position 4
    Beyond that its a case of whatever you feel you want to spend the cash on... rear ARB is easy to do, front ARB is a little trickier... steering rack one seems a little pointless unless you are feeling flush..
    <tuffty/>
    Mar 2013
    europe
    76
    hi , why do you advise using the tt bushes?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Quote Originally Posted by losing it. View Post
    The powerflex squeeze out and get damaged... TT ones are solid rubber, std mk4 chassis ones are voided... TT ones therefore are stiffer...
    <tuffty/>
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,357
    Quote Originally Posted by david7m View Post
    Hi
    All of em
    Midlands
    276
    <tuffty/>
    Cheers, the bloke from eBay link has quoted £265 for the parts, just need to get fitment price.
    Dave
    Midlands
    276
    Quote Originally Posted by Byzan Pics View Post
    All of em
    LOL. It doesnt seem too bad to me, but im in it everyday.
    Dave
    Mar 2013
    Devon
    405
    <tuffty/>
    Second this, seen many polly wishbone bushes pop out, and the retaining ridge separate.
    The only polly bushes I have seen outlast OEM and at the same time make a difference are the anti roll bar inner bushes.
    For OEM + fit S3 front arm bushes, and Skoda Fabia VRS rear beam bushes.
    Lemforder (OEM) or Meyle HD can be had for around £30 for the 6 bushes.
    Mar 2013
    europe
    76
    <tuffty/>
    Ok , il av to get the TT one s then as they look identical to the rear ones i had fitted , i just bought the powerflex ones erm by mistake by the looks of things.
    Midlands
    276
    Will it need a four wheel laser alignment after?
    Only place I've had it tracked successfully is Audi!
    Dave
    Mar 2013
    europe
    76
    Dave
    i had mine tracked just to makes sure, the guy who fitted the rear bushes got the rear aligned better than before just by eye so didn't have get it aligned but did just to make sure. Mine was put on a hunter wheel alignment machine and couldn't get the rear to match so had to compromise. Now found out also why they couldn't track it properly as front drivers side wheel bearing is very loose over a cm of play in both directions
    don't have tracking done at psi tuning, as they couldn't track a pushchair, i think they are the reason my bearing has gone ,they are incompetent at a lot of things.
  1. What bushes are worth replacing when changing suspension setup?
    By Dansmith in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th September 2010, 15:49
  2. what bushes wear on rear of quattro?
    By ian52 in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th January 2009, 22:48
  3. What's the funniest thing on the Web?
    By MikeS4 in forum General Chat
    Last Post: 29th May 2007, 22:33
  4. What's this flap thing??
    By Tallpaul in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th July 2006, 07:58
  5. Passenger seat - what are these metal things...?
    By skempster in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th March 2005, 17:27
