Results 1 to 8 of 8
    Apr 2011
    Hadlow, Kent, UK
    25
    Brake Booster Line Question (Regarding the pcv mod)
    Hi all,
    Only part of the PCV Mod I am worried about is the capping off the brake booster line. My question is, are my brakes going to work as normal if I cap the pipe off? Or will they ever fail one day because this pipe has been capped?
    Martin
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,593
    PCV Delete doesn't compromise the brakes if you are doing it right? what car is it?
    You should familiarise yourself with how this stuff works really before going in and doing this kind of work... how will you know if you have done it correctly?
    The brake servo requires a vacuum from the inlet manifold, this vacuum pipe also needs a one way/check valve (there should be one already fitted) to prevent boost from getting to the servo
    Which guide are you using?
    <tuffty/>
    Apr 2011
    Hadlow, Kent, UK
    25
    A3 1.8t AUM. I haven't done PCV yet that is why I am asking. The PCV sticky that is on here Guide - How to fit a catch can and simplify the PCV system If I do what it says in this sticky it should be okay and I wont have any problems Right?
    Martin
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,082
    Visit 16Klappe's Instagram Channel
    If you do what it says in the sticky then it WOULD be ok, otherwise we wouldn't have it as a sticky.
    I quite often say I'm going to do things.
    Then never do them.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,593
    Ok... I assume you mean this?
    If so then it will be fine mate... if you look the other part of this is still connected to the inlet and has a check valve inline too... this is the vacuum feed the brake servo requires and it will be fine to cap off as per the instructions
    <tuffty/>
    Apr 2011
    Hadlow, Kent, UK
    25
    Cheers guys that has helped a lot. You wouldn't know what parts I will need to do the mod? I know I need 19mm id hose, 2 90 elbows and a 19mm T, is there anything else I would need?
    Martin
    Mar 2013
    where can I buy a new one way valve as mine has failed
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,593
    Quote Originally Posted by BoostHard View Post
    TPS or a dealer...
    <tuffty/>
  1. TDI 170 Brake booster & associated vacuum lines
    By max69vk in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th May 2012, 21:10
  2. Question regarding the 312 caliper holders
    By influxsg in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th October 2011, 23:08
  3. Question about the S-Line and S3 Front Bumper Facelift
    By muktlee in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th September 2011, 11:12
  4. Somewhat weird question regarding punching the 2/3rd rear seat from boot
    By Scott in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th July 2009, 18:15
  5. questions regarding used chips
    By ImportRacer in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th August 2003, 17:45
