Volks AutosAH Fabrications
Results 1 to 8 of 8
    matt blowen's Avatar
    Jul 2013
    staffordshire
    137
    Add matt blowen on Facebook
    Disconected n75 valve
    Hi i have disconected my n75 valve just to see if there was much differance in boost! I didnt notice any change would this mean theres something wrong with actuator or n75? No faults found on vcds. When engine is cold and i tap the throttle the revs sit just under 2000rpm could this be linked in anyway? Cheers
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    Assuming you have electrically disconnected the N75 then there will be at least one fault code (N75 open circuit)
    Do you have a boost gauge? if so, what boost are you seeing? what model/year of car is it?
    What makes you think you have a problem that you need to disconnect the N75 in the first place?
    <tuffty/>
    Jul 2013
    staffordshire
    137
    Yes i just unplugged the n75, havent fitted a boost gauge yet, its v reg 1.8t seems ro rub crap when cold, idleing up n down and seems slow
    Scullies's Avatar
    Feb 2012
    Dubai
    1,240
    Scanned for faults after unplugging N75?
    tried unplugging the MAF?
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,318
    N75 disconnected on a stock 150bhp car won't really make any noticeable difference. Stock boost is barely above actuator pressure.
    Jul 2013
    staffordshire
    137
    when I disconnect the maf it runs smoother, I had the n75 fault code because I had unplugged it, plugged it back in then cleared all codes. should I try and clean the maf to impove my poor idle?
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    873
    Add Vex182 on Facebook
    Quote Originally Posted by matt blowen View Post
    Give the MAF a clean but be prepared to replace it, need doing from time to time to get the best from the car.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Jul 2013
    staffordshire
    137
    ok ill give a clean is there anything else i should clean while im at like the tb?
  1. N75 valve for 1.8T A4.
    By JayB5UK in forum Tuning
    Last Post: 22nd March 2006, 13:49
  2. N75 valve
    By in forum Tuning
    Last Post: 18th October 2004, 22:51
  3. A3 1.8T power increase trhough N75 valve!!!!!
    By manueltrigo in forum General Technical / How To
    Last Post: 19th April 2004, 10:48
  4. A quick question on N75??? Valve
    By simondavidr in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th April 2004, 21:31
  5. WHATS A ECS N75 VALVE ??
    By ooooaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th August 2003, 12:05
