Badger5EM Tuning
Results 1 to 13 of 13
    Aug 2011
    Plymouth
    732
    Add Lavis89 on Facebook
    Lacquer cracking
    Alrighty there, another problem! Towards the end of last year I took my car in to audi to get the roof resprayed were the rails had started to rust. Had the usual 70/30 deal offered to me.
    The problem occurred this week, I cleaned my car, and noticed the lacquer had cracked were the Respray happened. Do audi keep these things on record? I very stupidly have misplaced the receipt for the spray work and want to take things up with them, for a job they quoted over £1000 for I would not expect this to be happening!
    2001 1.8T Quattro Sport 89k covered ARY engine.
    Remapped at Badger 5, 213bhp - 235lb/ft torque.
    HS2K cone, FMDV008, Silicon TIP, 18" RS4 (reps), AP coilovers, Catch can, n249 bypass, Toyosport 3" Downpipe/Decat, S3 Front brakes, Polyflexed Dogbone, S3dave adjustable tie bars
    Soon to be done: SAI delete, Install the toyosport FMIC i have kicking about in my living room
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,254
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Yes they will keep it on record.....give them a call and advise them of this asap.
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    Aug 2011
    Plymouth
    732
    hopefully i'll have the car back on the road by the end of the week so will get up there asap, cheers
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,264
    Is it as bad as this?:
    This is my drivers A pillar and I believe it to be the original paint. Neve seen anything like it before!
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Aug 2011
    Plymouth
    732
    christ! no nowhere near as bad as that, it has a small bubble in it (1.5mm x2.5mm) and a crack right down through to the paintwork which has started peeling at the edges, i also noticed on a closer look after i got home from work that loads of the lacquer has started peeling around the rail itself in the roof gutter, definitely going to kick up stink, the paint hasn't even been on the car for a year.
    kwistof's Avatar
    Jun 2010
    SE Kent
    2,254
    Quote Originally Posted by Westy View Post
    My rocker cover looks like this
    I like to refer to it as the crackle paint effect
    Pretty scene so I hear and better than the rat look
    2000 S3 APY
    Squirrelofdoom's Avatar
    Feb 2012
    Surrey
    533
    holy hell Westy! Looks like a spiders web
    Westy's Avatar
    Dec 2008
    17,264
    Quote Originally Posted by Squirrelofdoom View Post
    It's slowly spreading up the pillar too. It's like when you break toughened glass!
    My car needs some serious bodywork!
    S3 Build Thread
    thegoal007's Avatar
    Another S3 owner....
    Apr 2008
    surrey
    724
    looking at your stats 0-60 in 4.8 secs.....your shaking the paint to bits.
    02 plate - 2002 - 225bhp - S3 - Ming Blue - completely standard - nuff said, OK there's a centre armrest, sunroof, BOSE speakers & black leather recaros, oh and the non OE chrome pack !
    Aug 2011
    Plymouth
    732
    bodywork on cars is the bane of my life (and my wallet). i'm a pretty dab hand with a spanner, and a nuclear welder by trade so no problems should i need any welding on the car, completely hopeless when it comes to paintwork though, i can't even get a half good finish with a rattle can
    Westy's Avatar
    Dec 2008
    17,264
    Found the cause of the issue!!!
    S3 Build Thread
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    What is that? Is that wen you had the windscreen replaced? Did you get all new seals aswell?
    Westy's Avatar
    Dec 2008
    17,264
    Just ha new screen and new seals. That A pillar is rotten as Fook!
    S3 Build Thread
  1. Peeling lacquer on alloys
    By lilya in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd April 2005, 13:17
  2. Cracked Windscreen
    By Ham6506 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th April 2005, 13:52
  3. Just got a cracking deal on some bits,how do i fit them?
    By ianhg in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd March 2005, 09:56
  4. Plastic window over VIN plate cracked and split
    By benk in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th August 2004, 08:51
  5. A4 Cabriolet windsreen cracks
    By 20006179 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th June 2003, 12:17
