Volks AutosChris Nott
Results 1 to 7 of 7
    Oct 2008
    188
    Updated fuel pump in tank or in line
    Ok after some more quailty advice from you guys Goan be running Siemens deka 630injectors 4bar fpr so going to run updated fuel pump any advice on witch pump to go for walbro or bosch in line or in tank
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    you are best off with a healthy std intank and fit a decent inline... 630's at 4bar you will definitely need an inline... thats best part of 500hp's worth of fuelling..
    <tuffty/>
    Oct 2008
    188
    Cheers mate I'm hopeing to be well into the 400s just 1 more question witch clutch plate did you go for I know you kept standard dmf cheers for all the help mate you seem to know all the awnsers
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,462
    See if the new genesis II intank is out yet from USRT.
    Id be snapping one of those up purely for simplicity, plus its very capable from the data so far.
    Otherwise stock intank and an inline like wallbro or da-31 is the norm round here.
    Apr 2011
    Dublin, Ireland
    566
    What was wrong with the Genesis 1.
    B5 v1 Tip, Relentless v2 Manifold, Beach Buggy Hybrid, Pipewerx D.P and cat bypass, Miltek resonated cat back, AH Fabs v2 Intercooler, S2000 Filter, 83mm 9.5:1 CP Pistons, Brute Rods, Bosch 550cc Injectors, Oil Catch can, N249 delete, B5 Phenolic Gasket.
    H&R Springs, Koni FSD Shocks, s3dave's rear tie bars, LCR Brembo's, 18" ttrs alloys, replaced all suspension bushes, 15/20mm spacers front/rear.
    Now just waiting on my B5 exhaust manifold as the Relentless is goosed.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,462
    Quote Originally Posted by IrishDave View Post
    fwd only. doesnt fit in quattro tanks. which i believe the Gen II will
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    Quote Originally Posted by djdougalno1 View Post
    std LuK pressure plate (just bought a complete clutch and didn't use the friction plate), std LuK DMF, Sachs 4 puck paddle plate... Sachs plate can be bought from Badger5 and the LuK stuff from GSF
    Sadly I don't know all the answers but I have pretty much done most of this before and is documented fairly extensively in my build thread...
    <tuffty/>
  1. Fuel Pump update on the 2.0TFSI K04!
    By Custom-Code HQ in forum Custom-Code UK
    Last Post: 3rd March 2012, 23:33
  2. In-line fuel Pump
    By Inertiauk in forum Badger 5
    Last Post: 11th November 2011, 09:10
  3. Replies: 3
    Last Post: 26th October 2011, 09:56
  4. tdi in tank fuel pump
    By tdi-man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th April 2010, 22:54
  5. help with in-tank fuel pump
    By SteveBAM in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st April 2010, 09:03
