Sky InsuranceAH Fabrications
Results 1 to 13 of 13
    valyboi's Avatar
    Oct 2012
    Mountain Ash, RCT, South Wales, UK
    119
    Add valyboi on Google+ Visit valyboi's Instagram Channel
    lowering my a3 should I get shocks too
    Hi
    I am thinking of lowering my a3 and iv found a set of just springs 60mm drop would I have to upgrade my shocks or could they cope with a 60mm drop. If I need to fit different shocks what ones would be best to use. Or should I buyback complete set as I'm on sleight budget atm
    Cheers Nick
    If a jobs not bodged,it's not done right.
    Sep 2005
    Derbyshire
    180
    Unless they are new I would recommend replacing your worn and tired dampers. I dropped mine on 30mm Apex springs and the ride was atrocious until I fitted decent dampers.
    valyboi's Avatar
    Oct 2012
    119
    So you would suggest to get spring and shock is it. Would coilovers be much differene in the ride
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,211
    For a 60mm drop I'd say change the shocks as well as standard ones won't last long with that drop.
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    valyboi's Avatar
    Oct 2012
    119
    Thanks DPM would using coilovers make the ride feel much different
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,459
    Coilovers would be a better option as the dampers and springs are matched (debatable tho), plus, in their lower settings there is less preload on the springs so makes for a more complient ride, seeing as you want 60mm drop, they should fit the bill perfectly. Plus there are some cheap options too, cheaper than spring and shock combos
    valyboi's Avatar
    Oct 2012
    119
    So you think I should go with coilovers instead as they are a all in package. I found them fk street coilovers on ebay also another set on ebay for like 155 few cheap sets on there would you recommend a set that's not to harsh
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,459
    There may be some info in the stickies on a3 coilovers, ive no experience of cheap a3 ones.
    I run AP coilovers on my s3
    Nyteryda
    Surrey
    222
    i had an a3 slammed on coilies and the ride was perfectly acceptable .. no harshness at all even with the 18s that were fitted. I cant say which make they were though which can make all the difference (probably cheaper ones).
    The ones on my s3 are rock solid and almost too much at times, especially on uneven road surfaces.. its not so much the harshness, more like the car follows the undulations in the road as opposed to soaking them up (can make you bounce in your seat a bit when pressing on)
    valyboi's Avatar
    Oct 2012
    119
    I'm going to have to try find them cheaper ones I don't want ones that a're rock solid my old corsa b was bad enough. Okay thank you I will have a look what I can find
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,116
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Look for the make you can afford/interested in and then have a little search as to what people think of them after they were fitted.
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/87813-definitive-cheap-ebay-coilover-thread-jamex-how-guide.html
    Majority of the cheapest brands are all the same with different labels/colour added afterwards.
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,211
    Quote Originally Posted by valyboi View Post
    As long as you stick with a good quality kit you'd be fine.
    Did you have a budget in mind?
    DPM Performance
    T: 01207 561606
    valyboi's Avatar
    Oct 2012
    119
    Yes I was only hoping to spend about 160 on a set
  1. Should I get adjustable rear tie bars when lowering?
    By g10chy in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th February 2011, 16:19
  2. should i get this car?
    By Cory in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th April 2004, 18:09
  3. Should I get this work done on my 1996 A6?
    By cble8869 in forum Classic Audi Forum
    Last Post: 12th December 2003, 16:42
  4. should i get the dv?
    By sash in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th October 2003, 14:44
  5. What colour rear clusters should i get ?
    By RussellFord in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd July 2003, 08:08
