AH FabricationsEM Tuning
Thread: Blowing sensors
    Jul 2013
    Glasgow
    Question Blowing sensors
    Hi guys,
    I have a 1.6 A3 8L. Owned the car for 2 years with no problems, however over the past few weeks it seems to continually trigger several sensors - the garage tell me they are the O2 sensor and the fact the car is running too lean -(more recently i get a front brake warning light, just changed my brakes 3 weeks ago, which is weird). We have changed the sensors several times, and looked for air leaks. Sadly the problem still persists.
    Has anyone experienced anything similar?
    Could it be related to a duff battery ?
    Thanks in advance for your time.
    Marty.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Actual fault codes would help... just because the engine is running too lean doesn't mean its the sensor... how do you think the ECU knows its running lean?... thats right... the sensor is telling it that it is... too lean codes are normally the result of airleaks or the MAF being faulty...
    We will need the actual fault codes are there are several it could be...
    18619/P2187/008583 - Ross-Tech Wiki
    18619/P2187/008583 - Bank 1; System too Lean at Idle
    16555/P0171/000369 - Ross-Tech Wiki
    16555/P0171/000369 - Fuel Trim; Bank 1: System Too Lean
    17559/P1151/004433 - Ross-Tech Wiki
    17559/P1151/004433 - Long Term Fuel Trim Additive Air; Bank 1; Range 1: System too Lean
    Fault codes are NOT definitive... you have to understand the conditions of how they are thrown... most of the time a fault code is the result of something else...
    If you are using genuine Bosch lambdas then I can't see how you have got through them... they are pretty sturdy... if they can withstand 900 degree exhaust temps from a 300hp turbo engine then I am sure they will survive a normally aspirated 1.6... biggest killer of lambdas is moisture
    <tuffty/>
  1. maf sensor
    By tvr1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2003, 09:52
  2. different mass air sensor?
    By brfoos in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th July 2003, 19:39
  3. Retro fit Parking Sensors
    By 18ME in forum General Technical / How To
    Last Post: 17th June 2003, 15:49
  4. What can knock a knock sensor?
    By MisterD in forum General Technical / How To
    Last Post: 20th May 2003, 13:53
  5. lateral accelerator sensor...
    By MimpiHantu in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th May 2003, 02:07
Tags for this Thread
