Monster MotorsportEM Tuning
    ShaunS3's Avatar
    Yorkshire & Humber Rep.
    Mar 2012
    West Yorkshire
    891
    S3 8L - Rear Roof / Tailgate / Boot Leak
    Hi guys,
    After doing a search and finding no results, I had to resort in posting a thread up.
    Whilst in the middle of terrential rain/thunder/lightning storms yesterday evening, i noticed the headlining being damp where the rear interior lights are.
    I proceeded to remove the plastic trim that holds it up and revealed a leak somewhere. The leak appears to be centrally sourced and then running both left and right down the trim due to its shape, ending up with the headlining being damp.
    At first, i thought the seal around the ariel had gone, letting water in but under the ariel inside was dry? I have had a look at the boot seal and could see no splits, but the leak appears to be further back from there and higher.
    I put my fingers in the two hinge holes/partitions and they appeared dry also. So i am now at a loss as to where the water is getting in.
    Any ideas?
    Shaun.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,789
    The seal on the aerial is pretty common to perish isn't it? I binned mine and fitted a shark fin as it was perished but didn't leak from memory.
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,235
    Right I can solve this . After a similar issue from 5 years of ownership I finally fixed mine.
    First is the aerial, remove it and silicone everything around. Next, where the hinges are, remove both plastic covers, 2 screws each, cake the screw areas In silicone then replace the covers.
    sit back and admire your leak free s3 .
  1. Rear roof spoiler
    By Grae in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th November 2007, 08:50
  2. Rear brake + CV boots - part numbers
    By nershen in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st May 2007, 17:14
  3. CV Boot Leaking
    By conker2 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd September 2006, 16:56
  4. Rear Wash Wipe, Water leaking from wheel arch!
    By Gajjii in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th July 2006, 01:13
  5. Rear roof rattle - SO annoying
    By benk in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th October 2003, 13:41
