Monster MotorsportEM Tuning
    Jul 2013
    Question Recaro Backrest Not Working!
    Hi ppl,
    Recently bought a 2000 reg Audi S3 that has some niggles!
    The switch on the side panel to adjust the backrest doesn't work. The lumbar and height work fine.
    Fortunately the position it's in is just about ok but it would be nice to get it working.
    Anyone had this issue or know a way to diagnose what's at fault?
    Thanks in advance.
    Chris
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,915
    Hello and Welcome
    Does the unit make any sound when the switch is pressed ?
    Jul 2013
    Hi, it doesn't do anything. However, both height and lumbar work fine.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,283
    It's my lumba that's broken on my drivers seat. I think best bet is to take te seat out for a good look at it. It's just too difficult in the car.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,915
    Sounds like a short in the wire as is no noise at all,I used to have problems with my seat and had it out loads of times,unplug airbag connectors underneath and then two screws at the front of the seat under the plastic cover by the carpet then you have to wangle it to get past the runner.
    When out I am sure its one screw and you'll have a bit more access to the back of the button panel,still tight though
    Jul 2013
    Sounds like the seat needs to come out then to get a good look - I guess if there is a short that could be a real nightmare to trace!
    I just wondered if there's an electrical circuit diagram to show what pins are used in the connection plug under the seat, I could use a miltimeter to test the function of the switch?
  1. Electric Recaro seat tilt not working... Now causing back problems -_-
    By Benjiman46 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th August 2012, 22:08
  2. S3 Electric recaro seats not working!
    By cdlaw in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th April 2011, 12:47
  3. Brake Lights not Working!! HELP!!
    By TDI in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th October 2003, 12:41
  4. URGENT - BRAKE LIGHTS NOT WORKING!!
    By Naresh in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th April 2003, 21:57
  5. heated mirrors not working.
    By moschino in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th January 2003, 17:14
