EM TuningVolks Autos
    Nov 2011
    pboro
    185
    inner cv boot replacement
    I noticed today a rather loud squealing noise coming from the passenger front. Only to notice the inner cv boot has split all the way round with no signs of any grease. And I have no idea how long its been like that tbh as never heard anything till now. How easy is it to change it? Do I need to take the whole shaft out or is there an easy way? The shop is trying to sell me gearbox oil, is this something I need as I thought it was just engine oil id need?
    Help appreciated guys
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    Hi,
    I had this happen on my drivers side recently. Best option is to buy the CV boot repair kit either from Audi or TPS its about £40 and comes with all the bits needed to do the job eg hub bolt and the grease too.
    I didn't fancy doing the job myself so got a local independent garage to fit it for me for about an hour and half labour charge.
    Make sure you get it done sooner rather than later as you don't want the joint drying out as then you may need to replace some expensive bits.
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    Think this is covered in tufftys thread, and a little in mine as i did two shafts using tufftys thread as a guide.
    Its a cheap fix, but its fecking mess thats all. Requires shafts out, no gearbox oil tho.
    You'l need a long extension for the shaft bolts, theres 6 bolts if i recall. Also a large socket for the main hub bolt, i think its a 12 point. And some circlip pliers and pinch pliers for the new clips. Think thats about it. Been a couple years since i did it on the audi tho
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,595
    There is a guide in the FAQ sticky...
    <tuffty/>
  1. Inner CV Boot Replacement - Difficult?
    By Ian W in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th August 2010, 22:20
  2. S3 Inner CV Boot
    By Welly in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th January 2010, 11:53
  3. CV Boot Replacement
    By edition in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th December 2009, 15:41
  4. Inner CV Boot
    By Trick in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th June 2009, 13:47
  5. 99 A6 steering rack boot replacement?
    By SiliconS in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 3rd September 2007, 23:41
